Scratch Build – In Progress Watercooled test bench build log.....Finished
Discussion in 'Project Logs' started by dead beat, 26 Jan 2012.
  1. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    Ok, so I started work on my watercooled test bench this morning. It's taking a little while as I've had to take quite a few measurements and make adjustments. Here is the progress so far. I expect I will be able to get this finished tomorrow.
  2. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    Look's good.
    Plenty of airflow for those rad's.
    Are you going to be using a mounting system to put a fan blowing air over the VRM's and South Bridge?
  3. dead beat
    15 Feb 2009
    Thanks Damien.
    Yes I have purchased one of the flexible fan mounts so I can mount a fan above the cpu block.
  4. Mojo
    Mojo Multimodder
    18 Nov 2011
    i'm loving the look of this!!
    I'd put it inside a glass box so that it could be viewed in all its mighty with noone able to touch it.. infact.. i wouldnt even turn it on!
  5. Conica
    Conica What's a Dremel?
    12 Jan 2012
    Looks Tidy, I like Tidy! :)
  6. dead beat
    15 Feb 2009
    I've been working on the bench some more this evening and have managed to get it finished. It's currently removing all the air from the waterloop. Anyway, here are the remainder of the pics....
  7. damien c
    31 Aug 2010
    Nice job!
  8. BlackDrag0n
    BlackDrag0n What's a Dremel?
    3 Nov 2011
    Nice and clean and tidy, looks great!
  9. dead beat
    15 Feb 2009
    Cheers guys. I'm very pleased with the end result.
  10. driftingphil
    driftingphil What's a Dremel?
    17 May 2009
    Looks very smart, bit like when you look a a valve amp with all the main working components on show!
  11. dead beat
    15 Feb 2009
    I've got one of those downstairs too........You mean a bit like this? (you can just about make out the valves through the grill)
