Way of turning off the sound on a specific program?
Discussion in 'Hardware' started by Jackarias, 13 Feb 2008.
  1. Jackarias
    Jackarias What's a Dremel?
    13 Jul 2007
    Hi. I won't beat around the bush, this is my simple problem:
    Basically, roller coaster tycoon 2 has no way of turning down the volume, or turning off the sound. and its insanely loud on headphones. so i cant wear headphones and go on vent etc when i play that game. is there a way of getting round that?
  2. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Can't you use windows volume control?
  3. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    delete all audio files associated with the game? :p
  4. Krikkit
    21 Jan 2003
    Or open them up in an audio editor and simply normalise them down to a sensible level. :)
  5. Jackarias
    13 Jul 2007
    like what? How do you use the windows audio thing to block out a single program? I cant delete the files as there are no clear cut ones. it seems to be merged all together. Theres no "audio" folder, just "game files" and they all have the same file ending so i cant differentiate.
    im a total noob at pcs.
  6. Dizman
    Dizman What's a Dremel?
    6 Jul 2006
    Is it vista by any chance? I seem to remember that vista had program-specific volume control.
  7. Jackarias
    13 Jul 2007
    No sorry, it's xp. I just tried using the xp volume control panel, doesnt work because the same slide affects vent as rct2. :(
  8. Krikkit
    21 Jan 2003
    Sounds like you're stuffed then! :p
  9. chrisb2e9
    chrisb2e9 Dont do that...
    18 Jun 2007
    just wondering but why do you want to turn it down for just that game? why not use the windows volume control to turn down the volume before you start to play. and then when you are finished, turn it back up. sure its a little bit of work but its not that hard to do each time.
  10. CanadianViking
    CanadianViking Beast from the North
    22 Nov 2007
    Yeah, but he says that he uses Vent, and turning down the whole volume would make it so he couldn't hear his buddies.
    Don't know how to fix your problem, sorry. Although, if I recall correctly, nVidia's software has very specific volume controls. Maybe check into that?
