Modding Weld-on 4 in the UK?
Discussion in 'Modding' started by sirbogey, 7 Jun 2005.
  1. sirbogey
    sirbogey What's a Dremel?
    7 Jun 2005
    Can anybody tell me where to buy the Weld-on 4 or a similar product in the UK? I contacted the manufacturer directly and they told me they can only ship it from the States and that would take 4-6 weeks. Are any of you in the UK using a different product?
  2. sirbogey
    7 Jun 2005
    :wallbash: I see! so nobody is glueing acrylic in this country!?!? :wallbash:
    any substitutes?
  3. Cowinacape
    Cowinacape What's a Dremel?
    26 May 2003
    You could also try asking for methelyn chloride (hopefully I spelt that right) where ever you go for you acrylic/plastics supplies. This will give you the same thing only with out the fancy "weld on" lable on the can. Hope it helps.
  4. sirbogey
    7 Jun 2005
    THANK YOU! that might be helpful aready! have a good one!
