Networks WELL NEED HELP With router will pay for your help.
Discussion in 'Hardware' started by ZincteK, 16 Jul 2004.
  1. ZincteK
    ZincteK Minimodder
    19 Sep 2002
    hello all about 2 months ago i got a old adsl ethernet/usb router off this forum of someone or it was bit tech cant remember but i never got it working right.
    its a eTEC ADSL MODEM ROUTER Model no. PT-3812
    i am running windows 2003 and i just cant get it working i didnt get the driver with the hardware so i cant even find that and i got abit of paper in the box which says
    etec ADSL modem router
    Ehernet/usb (PT-3808)
    Etec ADSL modem router
    4 ethernet port/usb (pt3812)
    product support:
    Email:support@puretek.co.uk
    The email address isnt working also puretek.co.uk isnt even a company web site.
    a picture of the product is below.
    pic here
    If someone can help me and get it working with me i will pay them 5er maybe 10er in paypal as i really want 2 get this working.
    Also i am using Zen as my isp and i have a static ip dunno if this will help
    thank you so much
  2. Gandi69
    Gandi69 Like to get busy wit fizzy..
    17 Jul 2001
    From what i've read there it should be able to be accessed via your web browser. Turn the Router on, and connect it up with an ethernet cable to your hub/switch/single PC. Now on a PC on the network (or the single PC) type in the IP of the router in your web-browser (usually going to be 192.168.0.1 or 192.168.1.1 or 10.0.0.1). All being well your should get up a config screen (after you've entered the correct password) then all you have to do is add in your username and password to the routers own modem configuration.
    If none of this works there should be a hardware reset button on the router somwhere: Hold this down for 10 seconds, then power off the router and power it on again. This should return all the settings to factory defaults such as passwords etc. Your best bet is looking on google for the default password and usernames or even an online manual for your router to set it up correctly.
    *Ps. This is a very rough guide, seeing as I though I have never used this type of router. Your best asking the person you bought it off for the password and username it uses, or the IP it resides on*
  3. apollyon
    apollyon What's a Dremel?
    20 Apr 2004
    more then likely unless the original owner changed it the standard password for the config screen is "admin", or some variation thereof, at least that has been my experience with most brands of routers
  4. Gandi69
    17 Jul 2001
    It all depends on the brand of Router. Try sourcing a manual mate :)
  5. Shepps
    Shepps Slacking off since 1986..
    5 May 2002
  6. MaxWiz
    MaxWiz What's a Dremel?
    1 Oct 2003
    The PureTek site also has the manual. That might help.
    Max
  7. Brew
    Brew What's a Dremel?
    8 Apr 2004
    Yeah i would start out with what Gandi69 says, find a way into the firmware. You might want to crack open its case and make sure its not crammed with dust too, I got a free switch from my school (2 of them actually) but one was loaded up with enough dirt to start a garden and was causing one of its ports to act funny. It was better after a good blow out.
    Brew
