Electronics What sorta wire to use for wiring LED to pc?
Discussion in 'Modding' started by NOMIS, 9 Oct 2004.
  1. NOMIS
    NOMIS What's a Dremel?
    7 Jun 2004
    Hey guys, I have never done this before ( or anything electronic for that matter ) and bought some LED's the other day. I need some wire to use to wire all the stuff together but what do I get?
    I found this
    page on a local shops website, but I do not know what type to get that would work with LED's.
    I don't even know if it is there, I can look around other shops but I would not know what I am looking for. I saw in the guide I am using (SteveyG's guide for connecting LED's) that the wire he uses has only 1 silver wire inside the colour, but I couldn't find one that looked like that on the website.
    If anyone can point me in the right direction, that would be greatly appreciated.
    Cheers!
  2. SilentDeath
    SilentDeath What's a Dremel?
    28 Jun 2004
    It'll work with LEDs, but it's kinda overkill.
    You can use 24AWG wire (~.51mm wire for non-US) just fine. You don't have to carry much current to a single LED, as most are around 20mA. I believe the wiring used from PSU to molex connectors is 18 gauge (~1mm), so if you're looking to draw a lot of power, use that.
  3. NOMIS
    7 Jun 2004
    I do not know what to look for. Is there any on this page I could use?
    I want to use the same as in the guide, a black for 0v and red as the other one.
    It says on the ones i posted 1A maximum current rating, is this good?
  4. modz-a-lot
    modz-a-lot What's a Dremel?
    28 May 2004
    just use a strand of cat 5e cable :D
  5. c.cam108
    c.cam108 Minimodder
    14 Feb 2004
    The first few are perfect.
    1A is more than enough for 10 LEDs.
    Just remember the resistor!
    _C
  6. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Yep, the first few on that page are ideal. :baby:
  7. Springs
    Springs Boing boing
    29 Aug 2004
    i just use speaker wire.... does me great...
  8. NOMIS
    7 Jun 2004
    Okay thanks for all your help dudes, yup I've got the resistors :p
    Now, I need to know, what size heatshrink tubing to use?
  9. NOMIS
    7 Jun 2004
    Can anyone answer that?
  10. Springs
    Springs Boing boing
    29 Aug 2004
    this is the size you want - 2.4mm.. thats the diameter of the heatshrink. i found that, thats the smallest size u want... a little bigger might be better it depends on how big you connections are
