*Air Cooling *Zalman Copper 'Flower' w/ 92mm quiet fan *IDLE: Case-22°C CPU-45°C *LOAD: Case-29°C CPU-55°C *AthlonXP1600+
air cooling volcano 9 = 3300 rpm idle core = ~322 case = ~304 load core = ~326 case = ~308 Thats in a room with sunlight pouring in the window ALL day, with no air flow of any kind, although i think hwdoctor is lying to me
Rig1: 2200+ OC'd @ 2600+ Coolermaster AeroJet set at about 2500rpm Case: Idle- 30 Load-34 CPU: Idle- 38 Load-47 Shuttle: 2500+ OC'd @ 3200+ The shuttle heatsink jobby Case: Idle-42 Load-47 CPU: Idle-43 Load-49 All temps using MBM5 so the mobo sensors. -cLoWn
Air #Swiftech MCX462+ and Enermax 92mm Pro #Idle Case=27c, CPU=47c, Ambient=25c #Load Case=29c, CPU=52c, Ambient=26c #AthlonXP Barton 2500+ @ 3200+
That's a lot of fans! Your case temps are higher than mine as well. I only use 3x80mm - one at the rear (stock Lian Li) and 2 at the front (coolermaster), and the front ones are running @ 7v. I only use a stock HSF too.
The case sits in a hot closet surrounded by clothes and towels. [edit]Its in the closet mainly because of noise, If anyone has ever heard a fully reved up Tornado then you know what I'm talking about[/edit]
So.. you put big, high cfm fans in a case to cool it... then realise it's noisy... so you put it in a HOT closet surrounded by clothes and towels. Something wrong with this picture, but I can't quite put my finger on it..
idle 43*c, load 55. but i usually turn up my fans when im gaming or doing something intensive and it usually hangs around the 47-48 mark when gaming with the fans running silent
even when all the fans are on quiet my temps never go above 43C. i left prime95 running all night once and the CPU was at 43 and the PWNwas at 45 after about 9 hours.
Air Cooled Lanboy, 40-42 idle, 46-50 load Case @ 30 min 35 max. Akasa 824cu CPU. Couple of nice old Antec Fans, much better than those dodgy 2500rpm ones you get. Think they're 4000rpm // 38cfm, about 35db each.
My friend sold my all 6 fans for $100CAD, I couldnt turn the offer down. So I put them in my case, which had no fans at the time(also all my PC's sit in my closet, Im a light sleeper and they all keep me awake, also its a huge walk in closet).
Air cooled Intel Celeron 700Mhz oc @ 723Mhz via AMD stock heatsink fan combo, and heatsink paste is AS5. Ambiant Temp: 70 Degrees F Processor Idle Temp: 74 Degrees F Under-load Temp: 81 Degrees F I get 90+ Hours per work unit on SETI with this setup; it's my main rig.
new HSF has made a world of difference!! #Your Cooling method : air #Make and model of Cooling method: GlacialTech 2520pro #Idle and load temperatures for both CASE and CPU: case idle = about idle temp and under load im getting 25 degrees C.. 2dC above idle! CPU is about 39idle ~46 degrees under load. thats a rediculous difference! delta 84CFM being mounted on it soon, thats about double the air shifting power of the current mwahaha, etc.
woah! something seriously wrong there. what client are you using? CLI or GUI? my duron 800mhz did 8hours 30mins per WU.
