Build Advice which motherboard?
Discussion in 'Hardware' started by stormbringer500, 1 Jan 2014.
  1. stormbringer500
    stormbringer500 What's a Dremel?
    6 Jan 2010
  2. Bede
    Bede Minimodder
    30 Sep 2007
    Do the cheaper one. It's a choice between 8 SATA and 10 SATA, and frankly if you're using that many SATA connections in a PC you're doing something wrong.
    Knowing more about your intended use would help though.
  3. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    ^ The man speaks truth regarding the amount of SATA, there is no need for 10 sata unless its a server ?
    Usually i'm a heatsink whore, but is the extra heatsink actually cooling anything that would affect its performance with regards to overclocking ? Probably not.
    Also - Gold, really Asus, really.
  4. Bede
    Bede Minimodder
    30 Sep 2007
    I quite like the gold, it's sophisticated like D&G (or is that Gucci?) :p
  5. stormbringer500
    6 Jan 2010
    Well I only thought about 10 sata ports, as I am using 7 at the moment (bluray drive, dvd drive, SSD, 3 HDD's and esata for front panel). Also which one would pair better with a 4770k.
  6. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Same chipset, so both will work fine.
    7 satas, jesus christ batman.
  7. Bede
    Bede Minimodder
    30 Sep 2007
    They both have the same chipset, they're both from the same manufacturer. Both will pair beautifully with a 4770K.
    Were I you though, I'd skip upgrading that 3570K you have and build a proper file server. Also isn't that DVD drive redundant seeing as you have a Bluray installed too?
  8. stormbringer500
    6 Jan 2010
    I was going to be passing this on to my dad as an upgrade, then try my hand at a 4770k. Also I still use the DVD for burning.
  9. narwen
    narwen narwen
    6 Aug 2010
    Pro for the intel lan
  10. blueviper11
    blueviper11 What's a Dremel?
    9 Sep 2010
