Modding Which of these 4 is the best LCD Keypad Design?????
Discussion in 'Modding' started by bsodmike, 19 Oct 2002.
  1. bsodmike
    bsodmike Banned
    11 Oct 2002
    Cool Hand, bro...I know how much you love abusing krylon..so would I!
    A) Got any part numbers for them switches at www.rswww.com???
    B) Where can I get the Krylon in the UK from an online shop?
    C) Do I need to prime the switches for the paint???
    Thanks, Mike...
    Is Blaggard still Down???
    Your the one that gave me the inspiration to start this ;P
  2. bsodmike
    bsodmike Banned
    11 Oct 2002
    Cool Hand, need a reply bro!!!
    Need a product code to check @ RS...
    Need to get these switches ASAP!!
    Thanks, Mike
  3. Cool Hand
    Cool Hand King of the park
    21 Nov 2001
  4. ReFredzRate
    ReFredzRate Relix Headshot!!
    2 Sep 2002
    Maybe this is stupid, but why dont you build yourself a remote control. The receiver can be plugged in to a serial port :D Saves you a 5.25" bay and you can impress all the ladies and fellow modders with your ultra schw33t computer system.... (sorry it's getting late ;) )
  5. bsodmike
    bsodmike Banned
    11 Oct 2002
    well, simply put, I have the Audigy Plat eX remote that will control winamp, but then again I will control my LCD when I'm close enuff to see it, I.E. NEXT TO IT!!!
    Using a remote then would be pretty lame, and I found the perfect switches:
    www.rswww.com
    4x 16mm Swtich, Vandal Flat: 278-1149
    9x SPST switch, black tiny as hell : 336-747
    Cost : £40
    LOL...
    Mike
  6. PC4LIFE
    PC4LIFE What's a Dremel?
    11 Oct 2001
    Sorry if this drives things a little offtopic.
    bsodmike how did you get your platinum ex to control winamp?
  7. Cool Hand
    21 Nov 2001
  8. PC4LIFE
    11 Oct 2001
    thank you for the link
  9. bsodmike
    bsodmike Banned
    11 Oct 2002
    Actually I was wondering about his for ages when some one pointed me out to the plugin. I dont think winamp has it. It's a plugin to control the R800 remote I think...
    I will find it and let you know if your still interested....
    Mike...
