which PSU (poll)
Discussion in 'Hardware' started by tintin, 27 Apr 2006.
Which PSU
  1. Fortron Source Epsilon 700W
    5 vote(s)
    10.6%
  2. Seasonic S12 600W
    30 vote(s)
    63.8%
  3. Other
    12 vote(s)
    25.5%
  1. tintin
    tintin What's a Dremel?
    6 Jul 2004
    After doing a bit of research my search for my future PSU is narrowing!!
    which one out of these two would your recommend for possible SLI/Crossfire, conroe, directx10 blah blah....
  2. atanum141
    22 Jul 2004
    Seasonic ANYDAY!
  3. tintin
    6 Jul 2004
    Okay seasonic is going into a 3-0 lead here!!!
  4. RotoSequence
    RotoSequence Lazy Lurker
    6 Jan 2004
    Seasonic all the way.
  5. hitman012
    hitman012 Minimodder
    6 May 2005
    I'd rank Seasonic up in the top 5 PSU manufacturers for definite. Very high quality, quiet units.
  6. tintin
    6 Jul 2004
    so do you reckon that the 100watt difference between the two is not really worth much - i know watt's arent the main thing!!
  7. Veles
    Veles DUR HUR
    18 Nov 2005
    Tagan make some very nice PSUs, quiet and reliable.
  8. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    well, I bought the FSP700W.
    A little more research says that I probably could have got away with the 600W Epsilon though at £20 cheaper.
    & yes, Tagan are good too.
  9. RotoSequence
    6 Jan 2004
    Why'd you even ask for our opinions then? You obviously had already decided one way since it was contrary to 80% of the advice given :eyebrow:
  10. hitman012
    6 May 2005
    Different poster ;)
  11. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Gonna go against the flow here and say get a Tagan ;)
    SOOOO nearly ended up getting a S12 600w unit, but been SUPER impressed with this Tagan so far. It's a touch cheaper than the Seasonic and the rails are a little better too :D
  12. Kobalt
    Kobalt What's a Dremel?
    26 Aug 2003
    I recently bought an antec 550W true power 2.0, (true control) with the volt control in front. I must say it's the best thing i've ever seen, i was able to almost double my OC without crashing, which was happening all the time with my other one if i went a bit too agressive.
    Now everything runs as smooth as a baby's butt, i'd recommend this one in a heartbeat :thumb:
  13. Amjedm
    Amjedm Minimodder
    2 Sep 2003
    Fortron are under rated IMO but Seasonic on this occasion is what you should go for.
    The Seasonic S12 series has been revised with longer cables (should fit in the P180 without probs) and all cables are sleeved. No idea when they will make it to the UK.
  14. RotoSequence
    6 Jan 2004
    Oops :duh: :blush:
  15. Goreblast
    Goreblast What's a Dremel?
    6 Apr 2004
    Macci uses the FSP which is good enough for me. Also they have a support forum on hexus.
  16. TMM
    TMM Modder
    12 Jan 2004
    I'd say the Seasonic due to its extremely good efficiency (though it doesn't really affect the power to your computer heh). I doubt you'd be dissapointed with any FSP, Antec, Tagan, or Seasonic powersupply though.
  17. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    Seasonic and FSP are both great makes, the only reason I went with seasonic is that I know its quiet and I don't know how loud the FSP is.
  18. Goreblast
    6 Apr 2004
    not very - got one here - everything drowned out by the x1900 crossfire setup to be honest
  19. tintin
    6 Jul 2004
    Thank you all for the comments!! i think i'm going to go for the Seasonic S12 now although the enermax liberty 620W is running it close....
  20. ashikamlani
    ashikamlani What's a Dremel?
    11 Mar 2006
    well the liberty is modular, and the seasonic not. IMO, its a simple choice. Modular PSU's are easier to work with.
