Guide your brushing techniques!
Discussion in 'Modding' started by Teyber, 24 Jul 2007.
  1. Teyber
    Teyber ******
    18 Mar 2007
    hey!
    im looking for a collection of brushing techniques. I want to brush the aluminum of my 100% custom case, as no paint i could find matched the quality i was looking for.
    So let me hear your opinions! like for instance, 120 grit then clear coat, 220 in diagonals, et cetera.
    and if anybody knows of some cool guides please, let me know!
    thanks in advace
  2. I'm_Not_A_Monster
    I'm_Not_A_Monster Hey, eat this...
    22 Dec 2003
    i just use my sonicare first on the upper teeth, then on the bottom, paying particular attention to the spaces in-between the teeth.
  3. Teyber
    Teyber ******
    18 Mar 2007
    lol!
    sorry if i was vague(i know your jokign) im talkign about gettign a brushed look on aluminum
  4. I'm_Not_A_Monster
    22 Dec 2003
    yeah i know lol, i've always just sanded with a block of wood and some fine paper (220 or maybe the 300 one, 340? 360?) in one direction only. don't cross-hatch or it looks like crap. i don't clear coat but i'm not afraid of battle scars on my gear
  5. Cheapskate
    13 May 2007
    I always just used a wire wheel with a drill. -Of course, my stuff looked like sh*t.
  6. Lian Li Lover
    Lian Li Lover What's a Dremel?
    17 Nov 2006
    There's a guide in the how-tos somewhere
  7. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    IIRC ther was one on the project log of the guy who made the projector
    Found the link Its less than I thought there was but there are some good tips.
  8. Teyber
    Teyber ******
    18 Mar 2007
    ah thanks spacecowboy! thats a good one
  9. I'm_Not_A_Monster
    22 Dec 2003
    did you floss beforehand? :)
  10. Cheapskate
    13 May 2007
    HA! maybe if I had gold fronts or something...
  11. zhangmaster12
    zhangmaster12 What's a Dremel?
    11 Jun 2006
    i think its called grills
    also, dont forget mouthwash!
  12. Jedda
    Jedda What's a Dremel?
    21 Jul 2007
    Am experimenting with a rad grill for my brushed silver case.
    If I get anything good I'll tell you.
    Had the idea of polishing then sanding in one direction. Just waiting for the rough aluminium polish that's used on truck parts.
  13. Teyber
    Teyber ******
    18 Mar 2007
    I tried belt sanding, and i got really course sanding, and really shiny! its cool it looks kinda like what jedda was talking about....
  14. I'm_Not_A_Monster
    22 Dec 2003
    just be careful with the power tools, shiny doesn't always mean smooth, it could be shiny but filled with small gouges that will take forever to remove
  15. saxman
    saxman What's a Dremel?
    21 Feb 2005
    man I would not like to have gouges and cracks in my gold fronts. I am thinking back to the good ol toothbrush.
  16. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    one of these things @80-120grit, then hand sand @180-200grit just to smooth it out before clearcoating (alu will oxidize if you don't clearcoat quickly)
  17. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    supertoad has got it, brushed aluminum is really "sanded in one direction" aluminum if the piece is flat and smooth, you can tape or glue sandpaper (around 200 grit) to a piece of glass then push the whole panel back and forth in one direction, belt sanders work quite well for this effect too
  18. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    Yea man. I've got some aluminum in my garage I'll try some stuff out and tell you what works best.
