Computer keeps 'cycling' after swapping graphics cards
Discussion in 'Tech Support' started by bixie_62, 26 Apr 2007.
  1. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    hey
    having a few issues with my computer, hopeing somebody on here can help.
    have 2 drives, both 80gb, one ide and one SATA
    booting off the SATA with seperate versions of windows (dual-booting-both legit xp's!)
    basically, i had it booted into the install on the SATA drive (install TWO) and i swapped out the radeon graphics card for a geforce 4 to test it out
    ran fine
    after removing the card and plugging the radeon 9800pro back in, the windows 'loading' screen comes up and then the computer just restarts!
    i've run Chkdsk on each of the three partitions on that SATA drive, i've used 'FIXMBR and FIXBOOT' commands, still nothing
    the error it throws up if i tell it not to 'reboot after error' is 0x0000007B which was why i ran chkdsk a few dozen times!
    can anybody help?! i'd really like to get back into that install! its got a lot of beta software on it that i cant really obtain again!(all legal by the way!)
    PLEASE HELP!
  2. Krikkit
    21 Jan 2003
    It sounds like you broke the cardinal rule of graphics cards - always change the drivers if you swap from nVidia to ATi (AMD). I'm not sure what you can do, try booting into safe mode and removing the drivers. Otherwise I'd say you've had it (well, as far as a successful boot goes). :(
  3. bixie_62
    bixie_62 Minimodder
    17 Jun 2004
    you see, the thing is, i didnt have ANY drivers installed!
    the drivers i was using were the standard microsoft ones, i dont use that install for anything other than some of the software stuff i do!
    didnt think it would be an issue
    cant even boot into safe mode!
    nothing that can be done?
    if i did a windows install on top of that one, would it salvage my user accound and documents at least?!
  4. Krikkit
    21 Jan 2003
    Have you tried putting the GF4 back in? I suppose windows could've eaten its own drivers trying to cope with the 2 cards - did you do a restart between swaps? (i.e. Did windows start for the 2nd time with the Radeon installed?).
