Case Mod - In Progress [颖]Project conceptmod - Acrylic tubing!
Discussion in 'Project Logs' started by ying, 7 Apr 2012.
  1. ying
    ying What's a Dremel?
    26 Aug 2011
    Custom valve system:
    When not using it:
    When I need it:
    Pump Station:
    In the past I used to mount the Dual D5 Top in horizontal with the EK reservoir combo but the space that this occupies was extremly large so I decided to mount the pumps with silentblock and screw them directly to the case. This system makes the pump quieter and occupies much less space:
    But one of the problem when mounting the EK dual top with the pumps in vertical is that there aren't space for the reservoir combo from EK so I decided to use a fillport:
    Custom Midplate:
    Render:
    Real life midplate
    And now, let's show the PC with all the watercooling stuff working!:
    Squigly likes this.
  2. Ulti
    Ulti Poor student
    20 Jun 2012
    I know I keep repeating myself, but once again, awesome work dude!
  3. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    ooo I can't wait to see the night shots! Great work mate!
  4. ying
    26 Aug 2011
    Thanks for your comments :)!
    I will take some night shots when possible because by now im very busy with studies :S
  5. ying
    26 Aug 2011
    The project is finished but there are some plates that were designed but never were done:
    In this case Im speaking about the mb tray plate:
    In the far future it's possible that I make it real but by now it's just a render.
  6. Wooojciech1983
    Wooojciech1983 What's a Dremel?
    28 Sep 2012
    Hi,
    This backplate looks absolutly amazing.
    The bottom part is made from plexi, not metal, right?
    So does it increse the temparature of the card?
  7. ying
    26 Aug 2011
    Playing with acrylic tubing!
  8. ali_robb2000
    ali_robb2000 What's a Dremel?
    17 Feb 2003
    Wow - thanks for reviving the thread, it looks great!
    Acrylic tubing looks cool but the other tubing was good too - pretty thick and you managed to get tight turns without kinking - what type of tubing was it? I've got Promochill Advanced for my current build, apparently that doesn't kink too easily...
    Was the acrylic easy to do?
  9. ying
    26 Aug 2011
    My old tubing was primochill primoflex (the previous to the Advanced version), so the advanced should be better :D
    The acrylic tubing is easy to bend with a heatgun and the result of all is astonishing :D
  10. Editor22
    3 Jan 2009
    Looks excellent Ying!
  11. ying
    26 Aug 2011
    Thanks Editor22 :D
    Your guide for cutting acrylic tubing is very very usefull and explains all very clear! So big thanks for all the effort you done :)
    More photos about the SLI connection:
  12. The_Crapman
    5 Dec 2011
    Some fantastic work there and a real beaut of a system. I've got a lot of love for 480's having owned a couple.
  13. ying
    26 Aug 2011
    Yeah! They still working great in most of the games and they looks very good at night with the custom backplates :)!
  14. The_Crapman
    5 Dec 2011
  15. ying
    26 Aug 2011
    djzic likes this.
  16. GotMod?
    GotMod? What's a Dremel?
    3 Apr 2012
    And you call it "Playing"??:jawdrop:
    One word - amazing!
  17. djzic
    djzic Bokehlicious!
    8 Nov 2010
    Awesome mod, love the backplates!
