News AMD unveils Ryzen processors, boasts of Intel-beating performance
Discussion in 'Article Discussion' started by Gareth Halfacree, 14 Dec 2016.
  1. faugusztin
    11 Aug 2008
    TDP's are often just brackets. 1700 might have fallen on one side of the 65W divider, while 1700X might have fallen on the other side. 60W => 65W bracket, 70W=95W bracket. Other option might been what Vault-Tec said, that is more aggressive clocks, staying at higher clocks for longer time, before thermal/TDP limitation come in the play.
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
  3. Vault-Tec
    30 Aug 2015
    Yeah I think the expensive ones will overclock quite aggressively. According to something said somewhere at some point (of which I can not remember) it was said that depending on your cooling etc Ryzen would clock itself as high as it could.
    I think that is why they did not talk about, nor set in stone, the boost clocks when they ran Blender and Handbrake. I think they were still working on it.
  4. Gareth Halfacree
    4 Dec 2007
    Dude, it's in the article - the one linked to the thread in which you are currently participating. :p
    What's interesting, there, is that it's called XFR and not EFR. What's the letter suffix AMD has chosen for its highest-end enthusiast parts - the ones with the oddly-raised TDP despite only minor boosts to stock clocks? Yup: X.
    I'm putting it out there: anyone want to bet against XFR being exclusive to the X chips? Fiver to the charity of the winner's choice.
  5. Anfield
    Anfield Multimodder
    15 Jan 2010
    Or the in between option:
    On the non X its like with Intels Turbo Booost 3.0 where it doesn't work on all cores while the X version gets it on all.
  6. Vault-Tec
    30 Aug 2015
    I agree Gareth, I think the expensive ones will do all of the work for you so you don't have to get your hands dirty. So for enthusiasts the 1700 will probably be the one to have so long as you are not scared by the overclocking part.
  7. Gareth Halfacree
    4 Dec 2007
    Could be - boosts performance while running two or four of the eight cores on the non-X, and all eight on the X. That maps quite nicely to a 50 per cent increase in TDP, too.
  8. RedFlames
    23 Apr 2009
    Looks like AMD are only [officially] supporting RyZen on Windows 10... linky.
    *idly wonders if they'll get the same flak intel did*
  9. Vault-Tec
    30 Aug 2015
    Silly decision, given that many won't upgrade to Kaby because they don't want to leave 7. However, it was obviously more trouble than it was worth.
  10. rollo
    rollo Modder
    16 May 2008
    Good decision by AMD, at this point windows 7 is just legacy support.
  11. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Just to follow up on this: AMD had said that all Ryzen chips would be unlocked, but actually, they specifically said "multiplier unlocked", per this slide (which VT originally posted a month ago):
  12. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Yeah, I even went with an i5 for my "budget isn't even a thing" machine, because why pay hundreds of pounds more for MHz you're never going to use.
    Also, gareth, I'll take that bet just to make things interesting. PM me when you win it otherwise I'll forget.
    Come to think of it, I'd better not win as I have absolutely no idea what charity to choose...
  13. Gareth Halfacree
    4 Dec 2007
    Huzzah! Nobody ever takes me up on these things!
  14. Vault-Tec
    30 Aug 2015
    What is believed to be a 1700X 8c 16t vs 6950x 10c 20t.
    Edit. 8C 16T Ivy @ 3.4
  15. Vault-Tec
    30 Aug 2015
  16. Vault-Tec
    30 Aug 2015
  17. faugusztin
    11 Aug 2008
    Also logic of that "per core" is flawed. Especially in the era when you have different Turbo clocks depending on core load count, new features like that new automatic AMD OC and so on.
    When you do a 8-core load and divide the result by 8, you might get a different "per core" score than if you did a 4 or 1 core load.
  18. Vault-Tec
    30 Aug 2015
    I know, hence the pinch of salt.
    Edit. Just to say. With all of these benchmarks and leaked info you usually have three scenarios.
    1. Total BS.
    2. Totally the truth, but usually on a ES or what not.
    3. Somewhere in the middle, which turns out to be correct after the launch.
    It's the same every single time.
  19. Isitari
    Isitari Minimodder
    6 May 2009
  20. Vault-Tec
    30 Aug 2015
