News AMD unveils Ryzen processors, boasts of Intel-beating performance
Discussion in 'Article Discussion' started by Gareth Halfacree, 14 Dec 2016.
  1. Vault-Tec
    30 Aug 2015
  2. Gareth Halfacree
    4 Dec 2007
    Huh - that's strange. I'm seeing some sources say XFR is X-only, and others that it's on all three. There's still nowt on AMD's desktop processors site to clarify matters, either.
    Looks like it's still up in the air whether it'll be me or Ending Credits who has to splash out £5 to charity, then!
    EDIT:
    You sure about that, Matt? NewEgg says the 1700X has XFR and the 1700 doesn't. Overclockers concurs, specifically stating "X Version with automatic XFR overclocking" on the 1700X page and leaving it off the 1700 page. If that's not the case, then AMD has really screwed up the messaging to retailers - and so close to launch, too.
    EDIT EDIT:
    Nup, looks like either the engineering team got it wrong or there's been a miscommunication: AMD's own Ryzen pre-order page clearly says "Extended Frequency Range (XFR) in the presence of better cooling" for the 1800X and 1700X but not for the 1700. A winner is (still) me!
  3. Yadda
    Yadda Minimodder
    25 Jul 2003
    If I understand correctly, there are three core frequency states (possibly only two on non "X" chips): base speed, turbocore and XFR.
    Is the turbocore speed locked for any given processor?
    Edit: I think I found the answer. Is it true that turbocore will be limited up to a certain speed (<4GHz), and to go faster you need XFR (and therefore possibly an "X" CPU)?
  4. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
    The problem is I am restricted in what I can say. The info in Lisa Su's speech is all we've been able to publish. There's much more, and I have valid reasons for my statement, but given the mixed messaging elsewhere it's obviously something they've dropped the ball on a bit. We will clarify in the launch articles on the 2nd.
  5. Gareth Halfacree
    4 Dec 2007
    Well done, AMD. Pre-orders open and a week 'til shipping and you're telling retailers the wrong thing. Well, I guess they had to screw something up - and it's better that it's the documentation than the silicon!
  6. Yadda
    Yadda Minimodder
    25 Jul 2003
    Scan have a couple of Ryzen pre-built systems listed. Interestingly, the 1700 (non X) is listed as "professionally overclocked" to 3.8GHz whilst the 1700X & 1800X are both "professionally overclocked" to 4GHz.
    If we're talking boost speeds then that's an increase of 100MHz for the 1700 and no increase at all for the 1700X & 1800X. :confused:
    https://www.scan.co.uk/shops/amd/ryzen
  7. Vault-Tec
    30 Aug 2015
    Looking at the price of the 1700? that's probably about the limit. There has to be a reason why it is £165 or so cheaper than the 1800x.
  8. Yadda
    Yadda Minimodder
    25 Jul 2003
    Yes, I agree. My first thought was a limitation/frequency ceiling due to no XFR but given what Dogbert has said, there must be more to it.
    Any thoughts on what's going on with the "overclocked" speeds of the 1700X & 1800X Scan systems?
  9. Vault-Tec
    30 Aug 2015
    Yup. They are probably just using what AMD have given them as a marketing tool.
    Drunkenmaster made a post yesterday saying that 99% of people don't overclock their rig. That is why OCUK sell OCed bundles (he didn't say that part). But yeah, it's just marketing really.
    Selling air again.
  10. Dogbert666
    17 Jan 2010
    They are likely referring to fixed, "all-core" overclocks.
  11. Yadda
    Yadda Minimodder
    25 Jul 2003
    Ah, ok. Cheers.
    I think I'll wait until March when all will become clear. :)
  12. Vault-Tec
    30 Aug 2015
    OK so without poking you, putting you under a spotlight and dripping water on your head it would seem they are using a similar "not exactly the truth" method Intel use on their turbo boosts.
    Example - my 2680 V2 is sold as a 3.5ghz CPU. Only when you have it in the flesh do you realise that's one core and all 8 run at 300mhz less.
    So Scan are simply propping the CPU up to the stated speeds by overclocking. Makes sense. Still charging for air though :D
  13. rollo
    rollo Modder
    16 May 2008
    Scans pre Overclockers bundles usually work out £30 cheaper for a warranty lol
  14. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Now it appears X=XFR has been ruled out could it indicate per core OC'ing?
    Based on screenshots of AMD's Ryzen master OC software we can set different OC's, voltage, and disable individual cores so could non-X chip be restricted to a single setting across all cores, while X chips allow per core tweaking and the disabling of cores?
  15. The_Crapman
    5 Dec 2011
    Do we have any idea on pci-e lanes?
  16. rollo
    rollo Modder
    16 May 2008
    Is It just me or has pc component prices really gone crazy. Scan want £131 for 16gb ddr 4 are they crazy.
  17. Corky42
    30 Oct 2012
    IIRC they all have 24 x3 lanes.
  18. faugusztin
    11 Aug 2008
    RAM/SSD shortage. Prices are rising since Sept/Oct last year.
  19. Corky42
    30 Oct 2012
    I heard DDR4 price rises were because smartphone are gobbling up the supply.
  20. RedFlames
    23 Apr 2009
    Same with NAND - demand, largely from increasing smartphone storage, is outstripping supply.
