Scratch Build – In Progress Bent out of Shape - Update 16 28.05.
Discussion in 'Project Logs' started by Ocelot, 15 May 2013.
  1. The_Crapman
    5 Dec 2011
    Oh boy this case looks sweet. Almost factory made. Top notch work there. Sub-a-dub-dubbed :)
  2. Archer
    Archer Talga Vassternich - Deserve Victory
    10 Jan 2011
    Powder coating is pretty thick, so the finish on the bare metal doesnt have to be very good at all. IIRC I dropped mine off with some nasty scratches, and asked them to give the parts a very quick sanding and they used an electric sander of some kind and all was good. Obviously though, if you give them a well sanded product it will be all the better.
    One thing I didnt think of at the time, all the holes you've got will also get noticeably smaller, I had to redrill all the holes on my chassis after powder coating, which wasnt a problem for me, but maybe you want to go 0.5mm larger and avoid that problem
  3. Cheapskate
    13 May 2007
    It's hard to give feedback because you are doing great.:D
  4. TheL4mka
    TheL4mka Minimodder
    3 Oct 2013
    Amazing work! :) Keep going!
  5. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Great design and project log! Rarely do such things combine in one project.
  6. keenan
    keenan Minimodder
    12 Nov 2013
    Spectacular!!! The amount of work you're putting in is exceptional..
  7. flix
    flix Minimodder
    5 Aug 2009
    Wow, so damn nice work :clap:
    But why didnt you cut the wholes for the aquaero direct into the top? without the original cover.
    Would look much cleaner
  8. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Great work there dude. How I wish I had that sort of equipment.. One day :)
  9. Evenge
    Evenge Minimodder
    16 Sep 2006
    So many scratch builds involving aluminum bending. I probably have to try it myself at some point. ;)
    Your work is really high quality! Great job! :thumb:
  10. thegyufi
    thegyufi What's a Dremel?
    21 Mar 2011
    fantastic work with this aluminum !! You seem to have great tools :D
  11. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Wow, lots and lots of work here. Very well done to you Sir!
  12. Canardwc
    Canardwc @French_fab_factorie
    22 Sep 2011
    Really nice and clean job!!!
  13. Umbra
    Umbra What's a Dremel?
    18 Nov 2013
    Great work, (I covet your workshop!) a few things I've learnt when working with metal especially ally are don't scribe deep measurement lines as they are a pain to polish out and I cover surfaces in lots of masking tape if I'm worried about them getting too scratched.
    As you've discovered bending brakes require some trial and error to get right and the bending capacities specified for some of them are a bit enthusiastic, does your brake have an adjustable top blade so you can adjust the distance between the folding edge and the top blade, I can't quite see in your pictures if there is an adjustment slot, my brake has this adjustment slot and you move the top blade back or forward and set it to the thickness of the metal to allow for the bend radius.
    adjustment slot on right arrow of picture set to the metal thickness between the two arrows.
  14. Yaka
    Yaka Multimodder
    26 Jun 2005
    :thumb:cool build, nice festool jigsaw as well. love festool pr0n
  15. jopers1986
    jopers1986 Minimodder
    7 Jan 2005
    Real nice! Is a bit reminiscent of an EVGA hadron, or an old school Lian Li... but nicer :naughty:
  16. montymole
    montymole Rigid Tubist
    24 May 2010
    respect for the hard work that it take to do this subbed
  17. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Very neatly done. I like builds like these.
  18. KidMod-Southpaw
    28 Sep 2010
    Very impressive work so far. Looking forward to seeing what else gets crammed in there! :D
  19. Razer2007
    18 Jul 2010
    Very, very neat work!
  20. Meelobee
    Meelobee What's a Dremel?
    5 Nov 2003
    The build is coming along very nice, impressive progress and it looks really good :thumb:
    I just love seeing those little inventive methods modders use, like how you made the lower gpu bracket, good stuff :)
