SketchUp Bit-Tech Digital 3D Render Gallery
Discussion in 'Modding' started by scooby, 6 May 2009.
  1. Nanosec
    Nanosec absit iniuria verbis
    28 Apr 2009
    OMFG !!
    Metric - to be honest, if i didn't know this was a digi render gallery showoff/competition i would have thought yours were actual pic's. The lighting and textures are, in a word, PERFECT
    Awesome job !!!!!!!
    :thumb::thumb::thumb::thumb::thumb:
  2. bocian
    bocian New
    15 May 2009
    The first attempt
  3. HaoKi
    HaoKi Lleno de anguilas!
    10 Oct 2003
    Nice one bocian. Sketchup and KT combo here in use?
  4. bocian
    bocian New
    15 May 2009
    background says it all:) Maybe next time will be better
  5. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    looks realy nice bocian and stuart. though I think you should add some ground, so you get some shadows.
  6. stuartwood89
    20 Aug 2008
    Here's a 'better' one:
  7. Metric
    Metric has a bazooka
    1 Jun 2009
    Swiftech MC8800 Heatsink kit
    For those who are using KT, try the MLT render setting, it will produce a much more realistic render.
  8. stuartwood89
    20 Aug 2008
    I can't seem to find that setting for some reason.
  9. Metric
    1 Jun 2009
    Should be setting #19 in the drop down list, when you start your render:
    You don't have to have it run all 10,000 passes, you can stop the render whenever you wish to (this is usually after a couple hundred passes).
  10. stuartwood89
    20 Aug 2008
    I had a feeling it would be that one. So how do I stop the passes then without canceling the render?
  11. bocian
    bocian New
    15 May 2009
    File>Save Image - then you can cancel the process
  12. stuartwood89
    20 Aug 2008
    Haha I've been going for 45 minutes and I'm only on 48.
    EDIT: Not double posting so here you go:
    Heatsink from an ASUS EN7600GS Silent:
    Still not perfect. The model itself still isn't finished and the brushed aluminium texture is still a little too strong, but it's getting there. Once I've finished the model I'll start playing around with reflections and lighting. For some reason there's an extra fin on the top surface, probably cause a tape measure isn't accurate enough for this kind of thing.
  13. stuartwood89
    20 Aug 2008
    Metric, where can I get that shiney wooden floor texture for you have there, but for KT? Their site has a wooden floor pack, but it doesn't look good close up.
  14. bocian
    bocian New
    15 May 2009
  15. stuartwood89
    20 Aug 2008
    Why thank you! I'll take a look on the KT forums on how to get those working.
  16. stuartwood89
    20 Aug 2008
    Danger Den Waterblock. Model not by me by the way.
    Yeah, I can't do acrylic.
  17. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
  18. loner1994
    loner1994 oc newbe (sort of)
    29 May 2009
    probably a bad question but where do you lot get your metal textures from
    all the ones i have are no good and have no shine to them
    im geussing that the shiny nes of a metal is some setting in kt but i cant get any good metal textures
  19. stuartwood89
    20 Aug 2008
    Yeah, the shineyness is determined by the value you set in the material editor, you may want to set it to something above 100 (probably over 500 if you want polished silver). Metric posted a link to a brushed metal texture and I used the PNG and set that as the texture, however for some reason the direction of the texture differs on each part of a surface, especially a curved one. Take a look at the Kerkythea site, there are a number of textures on there.
  20. loner1994
    29 May 2009
    i have found that mlt take to long go get a good picture so for those who cant wait 10 hours for there model to get to pass 500 theres the path tracing progressive mode that can give an amasing image in just 30 passes
