SketchUp Bit-Tech Digital 3D Render Gallery
Discussion in 'Modding' started by scooby, 6 May 2009.
  1. stuartwood89
    20 Aug 2008
    I take it you used KT for that render. Can you tell me what settings you used for the copper and metal for those renders?
  2. skreenname
    skreenname SFF Forever
    11 Jun 2009
    Stop laughing. :(
    I accidentally made the model 1/10th scale.
    So if a side is supposed to be 30cm, it's 30mm in the model. :wallbash:
    Also, I had trouble making fan blades so they just aren't there.
  3. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    skreenname, about the fans,check out the SCC :)
  4. matthewrblack
    matthewrblack What's a Dremel?
    23 Apr 2009
    Another one of mine
  5. Sir Digby
    Sir Digby The Supprising Adventures
    18 Jan 2009
    A generic waterblock I did for Sketchup / KT practice. Any suggestions on what I could improve with the render?
    I used the MLT setting but got bored a little too soon I think :worried:
  6. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Looks good to me!
    I'd use more eges on the curves so you don't notice that they are in fact straight lines. Also beveling the edges of the model.
  7. skreenname
    11 Jun 2009
    Thanks for the link Dark~3nergy.
  8. DrALQ
    DrALQ What's a Dremel?
    21 Jun 2009
    This waterblock is excellent, could you send me solidworks or autocad file, i will try to make it.
  9. dullonien
    dullonien Master of the unfinished.
    22 Dec 2005
    @ Sir Digby.
    The metal material is looking very generic, needs a bit of shine (not too much mind) and some imperfections would help. I'm not sure how KT works, is it possible to add maps, bump etc. to the material, like it is with 3ds Max, Maya etc.?
    Is there something odd happening to the barb holes in the plastic, as in they aren't quite holes?
    Other than that, as Aterius Gmork suggested, increasing the curve steps and adding some chamfered edges would help with the realism.
    On the plus side though, the plastic is looking good and will only improve with a better metal texture beneath. And of course the model itself looks fine and as this is only a practice exercise things are looking good.
    Sir Digby likes this.
  10. Metric
    Metric has a bazooka
    1 Jun 2009
    I'll be sending the Solidworks files out to you later today :).
  11. DrALQ
    21 Jun 2009
    Metric, thanks I have received the file, I suspect to this week I will do.
  12. Floyd
    Floyd Wire Twister
    4 Dec 2008
    Just a little something im working on. Its more or less a model of my case as it was not too long ago. Ill be updating the model to show my new additions soon.
    Modeled in Solidworks and rendered in Solidworks also because I dont know how to make a good render.
    And a pic of my case as it was:
  13. Metric
    1 Jun 2009
    Any updates on the waterblock progress so far DrALQ?
    Rendered an acrylic and copper version last night (9+ hours, reached a SL of 20)
    Those who are using Solidworks, if you want anything rendered in Maxwell, feel free to PM/email me :)
  14. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    Stunning as usual. But if I were to fabricate the plexi/copper design, I would use thicker plexi or a different material for the retention bracket since plexi would flex too much.
  15. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    Metric....
    Words cannot describe how awesome your renders are.
  16. Floyd
    Floyd Wire Twister
    4 Dec 2008
    I can model like a mofo in solidworks but I render like a 10 year old. Is Maxwell free to use? Im assuming no...
  17. HaoKi
    HaoKi Lleno de anguilas!
    10 Oct 2003
    I'd rather get some tips on texturing and mapping ;)
  18. DrALQ
    21 Jun 2009
    Metric, while in any way, there were complexities with the sizes, slots in the base too small, it's 0,4 mm, now I think to increase their size to 1 mm.
  19. loner1994
    loner1994 oc newbe (sort of)
    29 May 2009
    they have to be small for full working abiaty if yey where 1 mm some someone would have made it by hand by now
  20. jhanlon303
    7 Sep 2006
    Gentlemen and Ladies,
    I am just going to sit here and admire that which I cannot do. Awesome just does not do this thread justice.
    My congratulations to all in this thread.
    john
