bit-tech shopping
Discussion in 'Feedback & Suggestions' started by RTT, 19 Feb 2007.
  1. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Nodnol
    Yup, does the same for me, on both Firefox and IE (a three sided box on Ff, a 'hump' in the top line in IE) - both hyperlink back to the same page.
  2. RTT
    RTT #parp
    12 Mar 2001
    London
    Thanks (although I knew about it already) :) It's all my fault :D
  3. DougEdey
    5 Jul 2005
    Southampton
    Is it possible to remove filters where there's nothing under them? Like the Hard Drives have filters for 600-699GB yet there's sod all under them? There's like 18 filters for HDD capacity and as they are all hyperlinks they get very confusing.
  4. Guest-16
    Guest-16 Guest
    Doug: email me at Richard dot Swinburne at bit - tech dot net what filters and/or categories you think needs adding/removing. I've already submitted a huge list to Geoff and I'll just amend and add to it.
  5. The_Pope
    The_Pope Geoff Richards Super Moderator
    3 Jul 2003
    London, UK
    Or just email them directly to me if you like: geoff DOT richards AT bit-tech.net
    Indeed, I'm considering setting up a dedicated mailbox for readers to email bugs to. As you can see, there are LOTS of categories and there will be little bugs like this that haven't been found yet. Most of the time they are easily tidied once we know about them.
    And you're right - these Hard Drive filters make little or no sense. RTT is gonna check the feed shortly and see how easy a fix is.
  6. Blademrk
    Blademrk Why so serious?
    21 Nov 2003
    Here
    I'm going to order a corsair 1 GB Turbo Flash Vista accelerator (I know dabs sells them for £16 product code 4D6LDM ) so I thought I'd use the bit searcher to give you the credit, but it doesn't seem to come up in the listings (searched using keywords Vista, Corsair Flash ) but I just get copies of vista or USB/SD memory :duh:
  7. RTT
    RTT #parp
    12 Mar 2001
    London
    I've just taken a look and that product definitely doesn't exist - so it isn't your choice of keywords :)
  8. Ben
    Ben What's a Dremel?
    11 Aug 2003
    East Sussex
  9. The_Pope
    3 Jul 2003
    London, UK
    I can get that added next week if you like. Tis a very new product
  10. Blademrk
    21 Nov 2003
    Here
    Cheers, I'll hold off buying it till then .
  11. koola
    koola Minimodder
    11 Jul 2004
    Not sure if it's been mentioned before, but it's anoying for me.
    Clicking the down arrow sorts the prices from High to Low and vice versa for the up arrow. Wouldn't it be more logical to have prices sorted Low to High when clicking the down (i.e. Low) arrow?
    Overall, a good product, but these little things do p*** me off :)
  12. RTT
    RTT #parp
    12 Mar 2001
    London
    Up = Ascending, Down = Descending - isn't that almost universal? :confused: Overclockers.co.uk do it this way too - up arrow indicating price ascending and vice versa
  13. randosome
    randosome Banned
    17 Sep 2006
    although the down arrow would seem more logical humanly, just about every site uses an up arrow for lowest first (well of the ones i look at)
    then again if you look at an arrow - ^
    the smallest bit is at the top, and biggest at the bottom (if that helps you remember)
  14. DougEdey
    5 Jul 2005
    Southampton
    On most sorting methods it's not an arrow, it's just an arrowhead.
    Look at PHPMyAdmin style RTT, that'll work.
  15. koola
    koola Minimodder
    11 Jul 2004
    Now that you mention it, OCUK do use the same sorting method, but I've never used it as I've always sorted by catagory then brand and found what I needed.
    Maybe the Froogle way is the better way.
  16. randosome
    randosome Banned
    17 Sep 2006
    thats also the way amazon does it
  17. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    Stockholm, Sweden
    As well as neweeg, and tigerdirect, and all other commercial sites :p
  18. DougEdey
    5 Jul 2005
    Southampton
    You guys are all right, but the difference is that bit-tech shopping uses FULL arrows. Which indicates "This way" everywhere else uses the head only which indicates "big to little" or "little to big"
  19. RTT
    RTT #parp
    12 Mar 2001
    London
    It's on the list of things to be changed :)
  20. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Lake District, UK
    For me it seems really strange that the main navigation bar isn't there any more. (don't know if this has been mentioned before or not)
