Here's my iPredator Powder Facebook gallery: https://m.facebook.com/story.php?story_fbid=129833235292506&id=100629234879573 Buildlogg: https://builds.gg/bhbmods/the-ipredator-powder-custom-loop-all-in-one-gaming-pc-16861
Build log: https://forums.bit-tech.net/index.php?threads/an-actual-toaster-mini-itx-build.378700/ Video: http://tiny.cc/o3qksz
Here are mine! Half Life 2: Gordon freeman edition (CMWS 2017 1st in views), Broken Peace with lava effect painting, Mad Max: War Rig and Cracked Turbine (newmodcity 2012)
I might as well post this one here that I built a while ago: A mini ITX pc with a leather bag for a case. The left fan is for the GPU, the right one for a Noctua NH-L9i CPU cooler, the bottom grille is exhaust through the power supply. The black cable leads HDMI, power and USB to a flat panel touch screen display that also fits in the bag, alongside a small bluetooth keyboard and mouse. I made a Youtube-video about it.
Hello everyone! I leave you with the mod of my pc. It is a core p3 whose parts have been changed to create a radiator-distro-case. The components: ryzen 3900 + rtx2070 super. Motherboard, psu and gpu are from asus strix and the liquid cooling from ekwb https://imgur.com/a/Lr9B3SH and the previous album https://imgur.com/a/P9e58Yu
SILVERHAND TOWER MODD I have created this case mod starting from an old Silverstone RAVEN 01 from my old setup. BOARD: AORUS X299 GAMING 3 PRO CPU: INTEL I7 7820X LGA2066 RAM: 16Gb XPG D50 NVMe: AORUSRGB 512Gb SSDs: RAID-0, 2x1Tb SAMSUNG 860 EVO AIO: CORSAIR H100i RGB PSU: CORSAIR RM850i GPU: AORUS GTX1080 XTREME 8Gb It is my first integral modd and I have only used hand tools, it is a totally handmade work, so it is not entirely perfect. I've started by removing 5.1 / 2 bays and HDD racs to make room for a kind of stage where I'll put a Jonny Silverhand Kurogami figurine. I have added a lighting with UV LEDs and some white ones since I have used some UV paint in the decoration of the motherboard. In the front I have made a modification to fix the sliding door, I have opened some ventilation slits and I have added an acrylic window decorated and illuminated by LEDs and on top I have placed an acrylic with the neck of Jonny's guitar simulating that it comes out of the case. Inside I have also added a cover with ARGB led lighting in which SAMURAI can be read. I have also made a modification in the AIO to add a silkscreen with the SAMURAI logo. I have also made some modifications to the graphics card in the decoration with acrylic paint. To paint and decorate the tower I have used various techniques, spray, airbrush, brush, transfer, acrylic paint and enamel.
Fan mod for Meshlicious produced by the eminently talented @dynamis_dk - it looks like part of the original case and was very well packaged. This mod exhausts warm air from the area around the top fan of a 3070Ti FE as it was blowing directly onto the back of the motherboard and at first was causing the aio radiator to heat up rather alarmingly too.A quick undervolt later got things under control but there was still a pocket of warm air. Pretty darn pleased with this alu plate. A small mod but it's made quite a difference and I'm very pleased by how it looks.
Ohh yeah that is a good match, to say that was just the left over spray I had from a previous project I think that's worked out a treat! Wish I'd have had the though to throw you some black fan screw in the envelope too Did the fingers go into the pci holders ok without scratching the paint?
They did go in ok, a little sliver of paint came off which is a shame, but it's hidden behind where it slots in. Good thought about black screws, I might possibly have some somewhere and it would look pretty tidy.
Corsair 5000T Custom water cooled PC Build & Case Mod by Mnpctech Hardware Specifications Intel Core i9 12900K. Asus Z690 Prime Motherboard. 32 GB Corsair Dominator. ASUS ROG 3070Ti with Corsair GPU Water block. Corsair 850W PSU. Corsair 2TB M.2 Drive. 2x Corsair 360mm PC water cooling Radiators. Corsair Hydro CPU Water block. Corsair Hydro XD3 RGB Pump / Reservoir (Very Quiet, I'm impressed) Corsair 12mm O.D. Hardline Compression Fittings. 12mm Stainless Steel Tubing for Water cool Loop. 7" HDMI Motherboard header LCD Screen with Aida64. 3.5" GoOverlay LCD in PSU Shroud (In review). Mnpctech 360mm Overkill Custom CNC Machined Aluminum Radiator grill.
