Another Update!!! Ok, can't resist posting the pics of a filled M8 After adding 2.5 liter EK-Ekoolant blood red Still some air in the front Picture with some leds, but don't know if i keep these Other side a bit more careful so just in case everything is covered And again a build without leaks, maybe because this time I used EKWB rotery's After some hours The beautiful EK-FC680 GTX - Acetal + Nickel CSQ And the EK-Supremacy - Nickel All tubes filled
Awesome job man, looks great! Do you have any tips for planning what you need for the acryl pipes? Like how many fittings you need? I keep thinking I won't end up with straight lines like you did.
Update!!! It took a while, but here is on of the latest updates of the CaseLabs M8 build Because of some problems related to shipping and other stuff it took a little longer before i received the second Lamptron touch controller. Thanks to Highflow I received it so that I could continue The 2e Lamptron touch controller Not long after this I got the controller from Lamptron thanks Lamptron !!! Installed and tested. Works perfectly!!! Looking good i think Time to connect the cables Before the power goes on some detail shots I also have applied some SMD LED strips, which are made available by a good friend of mine from lumenledverlichting. Clenn Thanks!!! Above a white LED strip and underneath 2 red LED strips, and this on both sides And on top of the HDD coolers also a LED strip instead of a single LEDs Something wrong with this picture above Not anymore now!! Looks good with the lights and fans Up and running!!! Soon the final photoshoot
Final Update!!! After a long wait.... the final pics. This build was quite a challenge given the size and space to be filled. Now .... no more text only pics. Hope you like it!!! That's it!!! A lot of pics I know, but easy to read My thanks goes to the following persons who have made this build possible: Jim from Caselabs for providing the beautiful Caselabs Magnum M8 Maurizio Lamptron for the Fancontrollers and switches Freddy from Highflow for various products...best shop in town Marco and Ruud from Coolermaster for the PSU and gamegear And Gregor from EKWB for supplying the water cooling products and always having the confidence in my builds Clenn from lumenledverlichting for the SMD ledstrips Without these people, the build couldnt finish like it is now.....thanks y'all And of course the people of the various forums for the support and comments
