Create aluminum profiles for supporting the structure of the base, and finally begins of the various CNC cuts.
Terminal caps of the 8 tubes. Cutting of aluminum bar, finally I use the lathe and open a thread hole.
Aesthetic ferrules positioned around 8 tubes and anchored on the wood texture. internal and external mirrored cut.
It's true. I love the charm of industrial machinery and their work Thank you Gravity Thanks Coin, soon there will be the next step
Terminated the terminals caps. It's visible the contrast between gold and silver after the one between clock gears and relative pins with plates.
Clock Hands in 1.5 mm thick aluminum. They will also be anodized , but with a special color...different from the gold or silver.
