Scratch Build – Complete ⭐ [ COMPLETED ] The Time
Discussion in 'Project Logs' started by MPC, 5 Feb 2017.
  1. MPC
    MPC Minimodder
    24 Oct 2015
    Sleeving with Gosumodz high quality materials.
  2. MPC
    MPC Minimodder
    24 Oct 2015
    Create a hole in the top to manage the cables and the led inside the clock reservoir. The hole will be filled with glue to make the reservoir waterproof.
  3. Dr. Coin
    Dr. Coin Multimodder
    13 Sep 2013
    I am curious to see your wire combs in action, unusual shape.
  4. MPC
    MPC Minimodder
    24 Oct 2015
    Yes, it's a new shape to lock the 24-pin and 8-pin cpu cables on the plexiglass wall. :thumb:
  5. MPC
    MPC Minimodder
    24 Oct 2015
    Cutting steel inox cables to fix the clock with the basin.
  6. GravitySmacked
    GravitySmacked Mostly Harmless
    2 Mar 2009
    Coming on beautifully; I can't wait to see it all put together!
  7. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you very much Gravity :thumb:
  8. MPC
    MPC Minimodder
    24 Oct 2015
    Equipment the bulkhead connector whit o-ring to obtain cooling liquid in the basin. Using of bolts to block the electric motor and the main mechanism. Using of waterproof bearing.
  9. MPC
    MPC Minimodder
    24 Oct 2015
    Luxury computer storage system.
  10. MPC
    MPC Minimodder
    24 Oct 2015
    Many thanks to Aquatuning that sent me extra- material when I was working for the project.
  11. MPC
    MPC Minimodder
    24 Oct 2015
    Handmade realization loop cooling liquid of amazing brass tubes.
  12. Cown
    Cown Minimodder
    25 Feb 2012
    That's some serious attention to detail :eeek:
    Very nice work!
    I really like your workpad as well, where did you get it? :D
  13. GravitySmacked
    2 Mar 2009
    ^^^^ What he said ^^^^
    Looks amazing! :thumb:
  14. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you Cown :thumb:
    The pad to work is of Alphacool and it's really cool. The mat is anti-static and also has the meter in the lower part and it is really comfortable, it has allowed me to cut to measure all the power supply cables. Is called Alphacool Eisplateau Anti-Static work- and mounting mat 120x60cm and you find it on the Aquatuning website ;)
  15. MPC
    MPC Minimodder
    24 Oct 2015
    Final photos – Part one
  16. Cheapskate
    13 May 2007
    Pretty! :D With just the right amount of insane.:thumb:
  17. GravitySmacked
    2 Mar 2009
    Incredible build from start to finish; thanks for sharing it with us :thumb:
  18. MPC
    MPC Minimodder
    24 Oct 2015
    Thank you very much Cheapskate :thumb:
    Surely I always want to make something new and never seen before ;)
    Thanks to you for following the project :thumb:
    I will soon publish the other final photos ;)
  19. Dr. Coin
    13 Sep 2013
    Great looking case. With it one should loose track of time well playing a game...
    Will they include pictures with the pump running and lights on?
  20. MPC
    MPC Minimodder
    24 Oct 2015
    ahahahah it is better that we do not take into account the time when we play :D
    Of course, very soon you can see the illuminated case and also the pump system.
    Later I will also post the video ;)
