Case Mod - Complete Cooler Master "Mastercase Racing" 5 / Pro Custom PC, FINAL Update
Discussion in 'Project Logs' started by mnpctech, 10 Mar 2016.
  1. Guest-23315
    Guest-23315 Guest
    I'd have thought by now we'd have moved away from riveting everything into place... seems very 2004 Chieftec Dragon of them, particularly with those mid-plates and people very often replacing them with something custom nowadays.
  2. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    From a manufacturers standpoint,it a far superior fixing method than bolts,cheaper and almost 0 chance of failure. Its very easy to see why they use them. If someone can make themselves a midplate then a few rivets are not going to cause concern. My interest in this is that CM have marketed this case as modular but used rivets.....doesnt seem right to me.
    While fans are on topic,I use a small bit of insulating tape over the hole so the clip has nowhere to go,the magnet is a good idea...wont work on EK Vardars tho,the clip is plastic on those.
  3. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    @jojo, Thanks buddy!
    @Mankz, it baffled me as to why CM used rivets too, btw, Havent heard from you in awhile, hope everything is good!
    @BNEG, good tip! and riveting also saves in production costs, easier and faster for factory assembly workers over screws
    HAPPY EASTER! :clap:
  4. keenan
    keenan Minimodder
    12 Nov 2013
    Outstanding Bill! Can't wait to see the finished result..
  5. C3PU
    C3PU What's a Dremel?
    14 Dec 2014
    Top class as usual.
  6. mnpctech
    21 Apr 2003
    Thank you for tuning in and commenting guys! I scored this Gigabyte OC Force Z87X MB from a friend. Just need water block for the CPU. Still debating on GPU(s)
  7. mnpctech
    21 Apr 2003
    Some of you may find this guide I made over this weekend of interest. I rattle bomb a PC chassis with Plastikote's Engine Enamel paint. Great low cost alternative!
  8. Cheapskate
    13 May 2007
    [​IMG] rep
    -'Spring' in Minnesota, still in a coat and cap. :lol:
  9. mnpctech
    21 Apr 2003
    LOL, we finally hit 60F yesterday, hopefully it stays :worried:
  10. noobas4urus
    noobas4urus What's a Dremel?
    7 Oct 2014
    As long as it's not -20F it's spring here. Looking forward to seeing this one in person Bill!
  11. arduum
    arduum Minimodder
    10 Mar 2015
    I like this project!:rock::thumb:
    Reminds "gulf" poject
  12. mnpctech
    21 Apr 2003
    @noobas4urus, right on man!
    @ardumm, thanks for tuning in and commenting!
    I'm juggling time between my build and this deepcool genome build for computex atm
  13. mnpctech
    21 Apr 2003
  14. mnpctech
    21 Apr 2003
    Yes, I'm alive. Thank you for being patient. I had to halt progress on my build to fulfill commitments for Computex. Over the past 3 weeks I bought on 4790K for $225 shipped and $300 for reference GTX 980 on Ebay auctions. Fyi: Prices on used 980s are falling on Ebay as people upgrade to 1080s. I have one more build to finish, and I'll back on the track with this one!
    Here is the PC I created for Deepcool's booth at Computex, http://mnpctech.com/deepcool-genome-gamerstorm-mid-tower-atx-gaming-case-review.html
  15. mnpctech
    21 Apr 2003
    The extended holiday has bought me some time to work on my build. I recently scored EK water block for the Gigabyte OC force motherboard. It directly cools Intel Z87 southbridge (PCH), PLX PEX 8474 PCIe lane splitter as well as power regulation (VRM / MOSFETs) module. This will also compliment the stainless steel liquid lines nicely.
  16. ToddK
    ToddK What's a Dremel?
    3 May 2014
    You guys and your amazing paint... :thumb:
  17. mnpctech
    21 Apr 2003
    Thanks Todd! On that note, it hurt to make the 3/4" hole into the paint to route the 316 stainless steel pc liquid cooling tube from the front radiator, but it just makes sense this way. I need to pick-up a bottle of the GULF Blue paint, so I can touch up the exposed steel in the hole. I modified one of the INLET/OUTLET black rubber grommets from NZXT Phantom to finish the mid section hole. Last night I bent the first SS tube of the loop. The stainless steel compression fittings are my own design. I wanted fitting that discreet in size and matched the tubing.
    Mnpctech Stainless Steel 1/2" OD Compression Hardline Fitting
  18. mnpctech
    21 Apr 2003
    Just a small update as my free time to work on this is getting more scarce. I've been bending the tubing and learning the ways of the Stainless Jedi. I love the look of stainless steel. It echos the fuel and brake lines on race cars, but has it's own learning curve. In retrospect, the scale of PC chassis is just too small for the 1-1/2" bends you get with the SS bending mandrels I've found.. Suppose I could go thicker wall and make custom mandrel, but I'll try 3/8" OD instead of 1/2" OD next time.
    Specs: Stainless T-304/304L, Seamless Tube, 0.5" x 0.035" x 0.43"
  19. Quantum-192
    Quantum-192 What's a Dremel?
    1 Jul 2016
    Bill it certainly is a thing of beauty with that paint job and the MNPCTEC stainless fittings look awesome - you displayed them on Sunday's Monkey Video and I was impressed with their simple but effective style.
    Now, you just need to do them in brass and for 12mm tube and I know a build they would drop straight in very nicely :D
  20. mnpctech
    21 Apr 2003
    How many fittings in 12mm and what grade is the Brass?
    and Thank you! and glad to hear you watched the hangout, too :D
