Case Mod - Complete Cooler Master "Mastercase Racing" 5 / Pro Custom PC, FINAL Update
Discussion in 'Project Logs' started by mnpctech, 10 Mar 2016.
  1. Cheapskate
    13 May 2007
    It's Hijacking. What you spelled involves drugs and lube...:worried:
  2. Quantum-192
    Quantum-192 What's a Dremel?
    1 Jul 2016
    Infuriating iPad auto correct at work :D
  3. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    As it should be,I was just expressing my surprise at not seeing it as a detail,Im not a fan of it either but as a motorsport detailing 'feature' ,it has its place.
  4. Vault-Tec
    30 Aug 2015
    My eyes say "Wow that's pretty. I like the bolts. Those blue things look nice.. FAN WIRES FAN WIRES FAN WIRES!!!!!"
  5. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Thank you for feedback guys!
    Evie is Awesome, and Graeme is great guy, hope to someday visit his shop!!!! and Thank you soo much for supporting Mnpctech. Over weekend finished making 16,14,12,8,6,4 pin versions of 4-pin billet cable combs
  6. mnpctech
    21 Apr 2003
  7. mnpctech
    21 Apr 2003
    Finished painting the video card waterblocks, bridges, and backplates with Porsche 917 GULF Racing Factory Blue Paint.
    Dismantled GTX 980 Koolance Waterblocks
    Basecoat Primer on Koolance GTX 980 waterblock
    Basecoat Primer on Koolance GTX 980 waterblock Bridge
    Koolance GTX 980 waterblocks with Porsche 917 GULF Racing Factory Blue Paint
  8. Cheapskate
    13 May 2007
    OOOH. That should be a stock acetal color choice.
  9. B NEGATIVE
    8 Aug 2011
    It is rather pretty...like a early Fiat 500 blue...
  10. mnpctech
    21 Apr 2003
    Agreed, it's a refreshing color. Resprayed the front grill to match
  11. jojoharalds
    jojoharalds Minimodder
    30 Apr 2014
    Awsome paintjob Bill,
    really like what you did with the topfront panel
    Sent from my SM-G935F using Tapatalk
  12. Hellbilly
    Hellbilly What's a Dremel?
    18 Aug 2016
    I don't know if I've ever heard a color referred to as refreshing before, but I think you're right, it really is. I really love the paint job so far. That little bit of black pin striping really helps makes it all pop.
  13. Hasle
    Hasle nohasslemods›
    27 Sep 2004
    Loving the look of this Bill! Paint job is on point. Digging the top panel with the gauge and switches. :)
  14. noobas4urus
    noobas4urus What's a Dremel?
    7 Oct 2014
    You and your powder blue. Btw, found an old prom pic when I was flipping through my keepsakes:
    Bill, your case look like a car man, far out :rock:
  15. mnpctech
    21 Apr 2003
    @Stu, "Planet of the Apes Prom" LOVE it
    @Hasle, Thanks again for watching and commenting!
    @Hellbilly, Indeed, Thank you for watching and commenting!
    @Jojo, Thanks buddy! love your HotRod!
    Decided on dual serial for the SLI bridge so I had to cut and bend new SS tubing segments for entering and exiting the GPU blocks. Here is the Koolance SLI Bridge, GTX Backplate and Blocks
  16. GeneralFun
    GeneralFun Lurker with tools
    24 Feb 2014
    Whoa
    Your attention to detail stimulates my OCD! (That sounds worse than intended)
  17. mnpctech
    21 Apr 2003
    Haha, I appreciate the post! Thursday night I worked on the final tubing link from GPU bridge to the water pump. I had bent 3 different tubes from the Stainless, first two were slightly off, they could have worked, but the tubing didn't sit perfectly flush in the compression fitting. Finally after 1.5 hrs, I had bent and cut right piece. I looked up at the clock and thought "Ugh, I could have accomplished so many other tasks instead of working on this!" As many of you know, that motivation for perfection can be an asset or handicap at times. lf I feel my work has cut corners, then I've only let myself down.
  18. mnpctech
    21 Apr 2003
    On Saturday I received my DDR sticks, 32GB of Corsair Vengeance. The sticks were Black, so I hit local home improvement store and found a great aerosol substitute paint for the Porsche Gulf Racing Blue, it's Harbor Blue enamel paint by Rustoleum. I'm using these to create a DIY video guide to painting DDR heat spreaders, too!
  19. Cheapskate
    13 May 2007
    I liked the UV orange... :( You painted it blue. :(
  20. mnpctech
    21 Apr 2003
    heh, it just didn't feel right...
