Case Mod - In Progress Corsair 400 Case Mod Project: "Tribute to SERENITY firefly" ...
Discussion in 'Project Logs' started by mnpctech, 11 Oct 2011.
  1. Cheapskate
    13 May 2007
    I bet he's delayed because of scouring plastic dinosaurs.
  2. Nutman
    Nutman Never stuck with stock
    21 Oct 2008
    So it kicks off - I've been waiting for this.
    Now, I'm not as opposed to the rocker switches as Kosovar is, but they DO need some weathering. The brushed steel base plates look waaaaaay too shiny new.
    But it's a good start, and I somehow get the feeling that this project is much further along than what you're showing us? ;)
  3. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Haha, I'm working between different projects for CES atm, so not a lot of time to document everything.. Here is Left side panel progress... Everything looks clean atm, so ignore that..haha... It will be colored to match the panels from firefly's deck, then distressed and weathered with Copper accents, graphics from interior of firefly will be airbrushed.. side panel was created from interior of an old Dremel carry case, with wire loom, 5" conduit, 3.5" fan controllers, misc wires, misc LEDs bulgin panel LED...
    Round Modders Mesh for the grills in the side.
    http://www.mnpctech.com/moddersmesh.html
    yassarikhan786 likes this.
  4. OC Maximus
    OC Maximus What's a Dremel?
    7 Aug 2010
    Awesome theme build, lovin it!
    Can't wait to see it all weathered and dusty.
  5. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    I've seen the snips of the research you've done with the bloody "Reaver" goodness as well as finding picts of the Set work and prop work, and models from the movie.... That's why I ain't say'n dog yet about what you're do'n!... How fast is your outside low pitch btw :D
  6. mnpctech
    21 Apr 2003
    Thanks! :D
    I know... it looks way too clean. I have to fab everything first, before it can get paint effects. The updates have been a little sparse. I'm working on 4 different vendor display PC builds for CES, AND preparing to show my billet case accessories in person. on the Main Floor!!! So, if you're attending CES, Jan 10th - 14th, Drop by and say "Hi"
    I worked on the access panel for this project yesterday... The Mesh was epoxied with ScotchWeld DP-190, the strongest 2 part adhesive I've ever found in my 10 years of Modding. Yes, it bonds metal, but for decoration only.. It won't handle autobody work..haha
    and You need 3M's Applicator
    Amazon link
    http://www.amazon.com/3M-Scotch-Weld-Adhesive-DP190-Translucent/dp/B000WXHG1Q
    Honeycomb Modders Mesh for the side panel...
    Gum drop style LEDs....
  7. Cheapskate
    13 May 2007
    Makes me wonder what you are going to do to the interior...
  8. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    This, back-lit.
  9. mnpctech
    21 Apr 2003
    I don't know yet cheaps, but it will be easiest cable management job in my career
    Bare with me on this part, it will make more sense when I've taken more pictures of the panel. I'm making a junction box for the panel, from an old bezel top.. imagining the box suffered damage from some type of accident and caught on fire.. Gumdrop LED is cracked, one of the black wire looms will be disconnected with have melted wires exposed.. I'm still deciding on what looks right, as I go along.. I plan to head over to Home Depot's Plumbing aisle tomorrow for some copper pipe, hopefully I can get .25" diameter, maybe buy a pipe bender, (probably don't need one) and emulate whats I'm only guessing is coolant or misc fluid lines? (it's all pretend..lol) from lower right panel in this photo. I keep telling myself "need more copper implemented)
    fyi: all of the photos were taken on my iphone 4, then I email them to myself and edit later.
    cannibalized bezel piece, to be heated and bent into used and abused junction box for the access side panel show above..
    after heating and bending the plastic into box... added smoked acrylic piece on top, I reflected to myself "Make due with what you have on hand, and improve your skills"
    Dremel had a snack... The effect of having caught on fire at one time will be added with paint later
    One of the black wire looms will be disconnected with have melted wires exposed..
  10. LooseNeutral
    13 May 2010
    bare with ya :lol: . I don't have a clue as to what where this is a part of :idea: :eyebrow: went from the side panel mesh to the ships on fire :eeek: due to making due with hungry Dremel :hehe:
  11. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Bill, 0.25" inch copper tubing will probably be easier to find at a motor parts store as brake pipe.
    Plumbing pipe is generally 0.5", 0.75" or 1".
  12. OC Maximus
    7 Aug 2010
    Home Depot is also a good place to find that copper tubing.
  13. mnpctech
    21 Apr 2003
    @LN, haha...
    @I&W, good point, thanks!
    @OCM, I should find some other inspiration there as well
  14. mnpctech
    21 Apr 2003
    I did find 1/4" copper tubing at Home depot, so I'll creating some simulated liquid lines. painted the 2nd panel, Matte Black and installed 1/4" wide u-channel, used as trim around fan holes, sold for xbox 360 shells, but also works on PC panels.
    link
    http://www.mnpctech.com/xbox_360_window_trim_molding.html
    Industrial looking vented cover will be hinged..
  15. LooseNeutral
    13 May 2010
    O.O Shhweeet!
  16. mnpctech
    21 Apr 2003
    :D ^
    I didn't see a pipe bender for 1/4" OD copper tubing at Home Depot, but I think I can stuff the soft copper tube with bicycle brake cable cover, to prevent the tube from collapsing as I bend it around a pipe. I want to achieve 90 degree bends. We'll try this afternoon at the shop.
  17. LooseNeutral
    13 May 2010
    now lookie here :eyebrow: you going to show some of this crazy bike bender "Modmen" special episode? :lol:
  18. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Ghetto solution:- Fill the tube with water & seal the ends. Water cannot be compressed, so the tube won't kink.:thumb:
  19. mnpctech
    21 Apr 2003
    @LN, haha! .... How about a copper silly straw for cheaps :hehe:
    @I&W, good suggestion, if I can find something to seal it.
    heading over there now...laterz! :thumb:
    GuilleAcoustic likes this.
  20. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Another great mod ... more and more threads to follow :D. Keep up the good job :thumb: (+sub)
