Scratch Build – Complete Cygnus X1.
Discussion in 'Project Logs' started by Attila, 18 Sep 2008.
  1. tominated
    tominated What's a Dremel?
    28 May 2008
    that is godly work. i love it
  2. n0cturnull
    n0cturnull Desperate to MOD!! =P
    30 Aug 2008
    it turns out more than i expected! cool and slick design :thumb:
    are you gonna paint the mobo board?
  3. Attila
    Attila still thinking....
    22 Feb 2008
    Thanks. :)
    No, no painting, I like the look of aluminium too much. About as far
    as I'm willing to go is a coat of clear, or maybe anodising.
    I die a little every time I see someone spray the inside
    of a Lian Li. :hehe:
    So I was about to make a start on the back panel and then thought
    that I should do something about the closing mechanism.
    Very simple design it's just a question of making the bits.
    Just a rough drawing first.
    Then a proper layout on some 3mm plate for the arms.
    Then cutting out with a hacksaw.
    Then arriving at the final shape with some files.
    And here's the two arms of the catch.
    Then the body is laid out (this time on 2mm sheet), cut, filed and bent.
    And then we have all the components for a catch (one of two).
    And the finished product. Should look good after it's cleaned up.
    Just have to drill some holes to mount them to the back plate.
    It works well and flicks back with a solid click.
    Must go now and make the other body.
  4. The boy 4rm oz
    10 Apr 2008
    That turned out really well, nice job.
  5. DaveVader
    DaveVader Fast Action Response Team
    10 Aug 2007
    ingenious!
  6. skullen
    skullen Minimodder
    31 Oct 2007
    Nice, very very nice :thumb:
  7. Cheapskate
    13 May 2007
    Nicely done there.:D
  8. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Wowza!
    Very Nice oldnewby!
  9. jhanlon303
    7 Sep 2006
    Modders making their own latches - what is the world coming to? Excellently done.
  10. Attila
    22 Feb 2008
    Thank you all. :)
    Finished the second catch.
    The next step was to have been the back panel but I made a really bad error, and
    unfortunately it can't be saved. So I must wait a few days until there is time to go
    and get another piece of 3mm plate.
    In the mean time work started on the small panel to hold switches and I/O gear.
    These are the items that will be attached to this panel, large power button with
    blue light, small reset button with red light (this will be connected to HD activity connectors).
    And the I/O module.
    The panel is on 3mm plate.
    Now I don't have drills big enough for the switches so they will be filed to the
    right size. Don't need to go crazy here because both sides of these holes will
    be covered.
    That's all the holes done to a rough state.
    And it looks OK even before sanding and cleaning up.
    Now I have to go and cut through the two front panels to accommodate
    the switches and wiring.
  11. The boy 4rm oz
    10 Apr 2008
    I too are a fan of a nice piece of alu, needs to look nice though. The alu in my LEXA had no "texture" no hair line brushing so I chose to cover than bad alu with paint lol. Even the brushed alu front of a LEXA is in fact plastic, not alu.
    Switch panel looks great. Nicely spaced, nicely laid out.
  12. ModMinded
    26 Aug 2008
    Oh no you don't! How dare you gloss over the "really bad error", especially after showing us the beautifully made catches, and before that cool front panel stuff! You think we wouldn't notice, if you just slipped it in there? :p Personally, as much as I love seeing the excellent craftsmanship, I enjoy seeing the errors as well (to learn from & to recognize the humanity in all of us, even the crazy perfectionistas seen here on bit-tech!) :wallbash:
    So what happened to the back panel?
    please :D
    And in case you missed it, I'm liking your work! I'm curious to see how the catches will fit into the overall case.
  13. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    some incredable alu work!
  14. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    With ^^
  15. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    you may consider filing down, or replacing the standoffs for the usb/firewire module so it sits flush with the front of the plate, or perhaps countersinking it. i believe it would look much nicer. i really like some of the ideas you came up with for your design. looking forward to seeing some more.
  16. Rozzy
    Rozzy I'll get there :P
    1 May 2008
    that switch panel looks amazing :) Really like the look of the plain alu.
    Keep it up
  17. DuVeL
    DuVeL What's a Dremel?
    4 Apr 2007
    Wow, nice stuff you're making.
    I'm going to follow this 1 for sure.
    BTW, should you make a vid or such with this comp, add this to your background music; Youtube; Cygnus X - Superstring from Rank1
  18. Cheapskate
    13 May 2007
    Props for the startled bear on the top of the plate.:D
  19. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    ^hahahha.
    Nice metalwork, man. This is coming along excellent! The catches look awesome.
  20. Nexxo
    23 Oct 2001
    Extremely tasty. I like how you really use the sheet aluminium's properties to guide the construction of the case, and how well finished it all is. :thumb:
