Guide Dimensions for anyone making their own case
Discussion in 'Modding' started by DeX, 25 Jan 2003.
  1. Spotswood
    Spotswood Custom PC case builder
    30 Jul 2007
    Do you mean Form Factor of 5.25" CD Drives?
  2. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Thanks spotswood thats what I was after what the usual gap between drives? or is it fine to have them flush against each other?:) :rock:
  3. kinghong1970
    kinghong1970 Just a Clumsy Ape
    19 Apr 2009
    anyone have a link for form factor for slim cd drives that are used on laptops?
    thanks in advance.
  4. Spotswood
    30 Jul 2007
    Cheapskate likes this.
  5. bluc
    4 Apr 2012
    Anybody have the dimensions for power supply mounting holes and exhaust airflow cutout? Sorry dont know how I missed it its in the atx specs pdf
    EDIT: anybody know if the power supply mounting holes have changed since atx version 2.01 there is no power supply spec drawing in the latest atx pdf
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    There you go...
    NOTICE: All holes are mirrored to allow for installing in any direction.
    Blooddrunken likes this.
  7. bluc
    4 Apr 2012
    Legendary thank you just what I needed!!
  8. tekonivel
    tekonivel Minimodder
    14 Jul 2012
    this thread is awesome!
  9. Blooddrunken
    Blooddrunken In Flames we Trust
    8 Apr 2010
    Thanks and +rep @jrs77
  10. GotMod?
    GotMod? What's a Dremel?
    3 Apr 2012
    Does anyone can help me to figure out lamtron fc5 front bezel dimension?
    Need it to create a cnc cut template, wanna do something like this
    I would appretiate any help, thanks!
  11. jrs77
    jrs77 Modder
    17 Feb 2006
    Measurements are done via photo-comparison in Photoshop, but they should be rather accurate.
    GotMod? likes this.
  12. GotMod?
    3 Apr 2012
    Thanks a lot! That's exactly what i was looking for!
  13. Arcis Modz
    Arcis Modz What's a Dremel?
    31 May 2015
    this will surely ease my work... :D thanks
  14. rogergamer
    rogergamer What's a Dremel?
    3 May 2015
    anyone got the cutout and mounting holes for a SFX PSU? (SF600)
  15. Trance
    Trance Two steps forward, one step back
    6 May 2009
    Generally PSU's don't have standardised cutouts as far as I can tell, you just need to incorporate the mounting holes.
  16. rogergamer
    3 May 2015
    cool, thanks!
