Hardware EVGA Classified SR-2 Review
Discussion in 'Article Discussion' started by Sifter3000, 17 Aug 2010.
  1. Sifter3000
    Sifter3000 I used to be somebody
    11 Jul 2006
  2. ImInTheZoneBaby
    ImInTheZoneBaby Bring it on sucka!
    8 Aug 2007
    I'm not really sure what to say... Overkill, perhaps?
    And the price... Ouch. :L
  3. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    One thing to say for this, and I've found it with my dual Opteron system too, is that in five years everyone else will have upgraded two or three times and you will still be able to keep up. While not perhaps future proofing, boards like this have a significant lifespan due to their expandability.
  4. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    Definetley overkill it's PPD per day is equivelant to Two Months PPd for me adn that's assuming i leave it running 24/7 which i don't.
  5. Jipa
    5 Feb 2004
    Sure, it's a fancy board, but I still think for overclocking I'd grab a single CPU system and for the day in-day out, 24/7 grind it's no better than other offerings as overclocking such a 24/7-calculator would never cross my mind.
    Still, love to see manufacturers try something new.
  6. StoneyMahoney
    StoneyMahoney What's a Dremel?
    10 Jul 2009
    Hmm, one of those kits plus all the necessary ancillary kit to support it or an upgraded Mac Pro...
    ...that's actually a tough decision.
  7. SlowMotionSuicide
    SlowMotionSuicide Come Hell or High Water
    16 May 2009
    Well, definititely something to get if I ever come across absurdly large sum of money.
    Liek this.
  8. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Good work guys at Bit-tech... great review and a very big one too :) Keep up the good work.
  9. unclean
    unclean SMP obsessive
    30 Dec 2003
    Not sure why the hate on the NCCH-DL. Personally have had much better results with it than the PC-DL. (Dual 1.6GHz LV Xeons @ 3.3GHz stable)
  10. r3loaded
    r3loaded Minimodder
    25 Jul 2010
    This is one of those things where "if you have to ask why, it's not for you" :p
  11. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    This review made me slightly aroused.
    llamafur likes this.
  12. crazyceo
    crazyceo What's a Dremel?
    24 Apr 2009
    This review left me slightly limp.
  13. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    How come the picture of BT's sample has the exact same configuration as Scan's? Same CPUs, same coolers, same fans, same overclock... :eyebrow:
    Anyway, great to see EVGA push the boundaries but I don't think anybody using it for non-business stuff really needs anything like this.
  14. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    I presume you're referring to the image on page 15? If so, that's a photo of the Scan pre-overclocked bundle.
  15. rehk
    rehk What's a Dremel?
    21 Feb 2010
    Utterly insane if you ran a 4x GTX460 folding@home farm using this, 11 6 pin connectors!
  16. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Yep - it needed two power supplies and heated the lab to such an extent that everybody bar me ran away for a few hours :brrr:
  17. Hustler
    Hustler Minimodder
    8 Aug 2005
    This setup has both me and my Pc feeling small and inadequate in every way.......
  18. perplekks45
    9 May 2004
    I was referring to these two pictures:
  19. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    Ah, ok, I can explain:
    The first picture is of the Scan bundle.
    The second picture does use the same CPU coolers as the Scan bundle (they did supply us the kit after all) but if you look closely this picture also shows our G.Skill RAM installed instead of the Corsair RAM that Scan supplied with its bundle.
  20. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
Tags: Add Tags
