Graphics Fermi vs 5870 in crysis at 25x16 dx10?
Discussion in 'Hardware' started by wyx087, 23 Mar 2010.
  1. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    its over 9000
    i'll get my coat
  2. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Pencil me in for 11 minimum.
    Guesstimating at around 5-7 for average, though. May seem a bit high for anyone who's followed by posts about Fermi, but I don't doubt they'll be fast... just not worth it for anything but benchmarks :)
  3. Jasio
    Jasio Made in Canada
    27 Jun 2008
    5 FPS more.
  4. wyx087
    15 Aug 2007
    just did a 2560x1600 test on my 24inch monitor, i guess Crysis renders at full resolution and then displays at maximum available to your monitor.
    Code:
    TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
    !TimeDemo Run 0 Finished.
        Play Time: 83.32s, Average FPS: 24.00
        Min FPS: 16.35 at frame 138, Max FPS: 28.37 at frame 1011
        Average Tri/Sec: -4370225, Tri/Frame: -182062
        Recorded/Played Tris ratio: -5.03
    !TimeDemo Run 1 Finished.
        Play Time: 80.00s, Average FPS: 25.00
        Min FPS: 16.35 at frame 138, Max FPS: 28.86 at frame 992
        Average Tri/Sec: -4226351, Tri/Frame: -169045
        Recorded/Played Tris ratio: -5.42
    !TimeDemo Run 2 Finished.
        Play Time: 79.84s, Average FPS: 25.05
        Average Tri/Sec: -4190987, Tri/Frame: -167301
        Recorded/Played Tris ratio: -5.48
    !TimeDemo Run 3 Finished.
        Play Time: 79.77s, Average FPS: 25.07
        Min FPS: 16.35 at frame 138, Max FPS: 29.09 at frame 1001
        Average Tri/Sec: -4241286, Tri/Frame: -169157
    TimeDemo Play Ended, (4 Runs Performed)
    for reference, 5870 gives around 16 minimal FPS, if gtx480 gives 8 more FPS than 5870, that would mean it's producing 50% more performance at 24 FPS.........
    seems a bit far stretched because only 10 to 20% increase is expected, perhaps 30% for Crysis.
  5. Showerhead
    Showerhead What's a Dremel?
    11 Jan 2010
    4 more at minimum.
  6. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    6fps min
  7. DorkSterr
    DorkSterr Hakuna Matata
    29 Nov 2008
  8. Quavr
    Quavr Minimodder
    3 Jul 2009
    13fps at minimum :)
  9. j_jay4
    j_jay4 Minimodder
    23 Apr 2009
    I think they'll be dead on identical
  10. el2k
    el2k Modder
    18 Jan 2010
    13, exactly around about kind of nearly.
  11. FuzzyOne
    FuzzyOne
    19 Sep 2002
  12. Elton
    23 Jan 2009
    I'd say +7, it's a bit pessimistic, but hey.
    Although on optimized games...probably +15
    On unoptimized, about +5.
    Avg: +8.
  13. fingerbob69
    fingerbob69 Minimodder
    5 Jul 2009
    +2 but running v.hot (over 90c)
  14. hrtz_Junkie
    hrtz_Junkie Controversial by Nature
    25 Jul 2009
    my guese, well 9 jumped to mind but considering this is a very high rezolution (traditionally nvidea's territory)
    I'm gonna go higher and say 13, unlucky for some!!
  15. kenco_uk
    28 Nov 2003
    Is there a prize?
    I'd say 7.
  16. Krikkit
    21 Jan 2003
    Will rep points suffice?
  17. wyx087
    15 Aug 2007
    i don't remember there being any prize for the Fermi transistor count, so no, not from me, sorry. although perhaps a digi-cookie.
    or Krikkit may add a few rep points to you, if you be nice to him :)
  18. dec
    dec [blank space]
    10 Jan 2009
    at least 12fps faster
    @personaboveme - how many transistors does it have? Im thinking a crapload since radeons have like 2 billion and are fairly small chips....so Fermi has like....a trillion?
  19. barndoor101
    barndoor101 Bring back the demote thread!
    25 Oct 2009
    3.2 billion transistors apparently.
    a hd5870 has around 2.1 billion
  20. memeroot
    memeroot aged and experianced
    31 Oct 2009
