Not sure really, but the challenge is there. Maybe someone can get it to run on a 486dx or something?
Challenge accepted! I have a 12 year old Mesh at home, if I fiddle with that for a bit, maybe knock the awesome CPU power down a bit, it might just beat your epic score Lysol.
Benchmark SummarySection Description Score Geekbench Score Geekbench 2.2.3 for Windows x86 (32-bit) Integer Processor integer performance 9592 9124 Floating Point Processor floating point performance 11031 Memory Memory performance 6018 Stream Memory bandwidth pe
Fastest AMD for me, then. Hrm. Managed to up it to 9911 from just putting in a confirmed working module, brought me up to 12GB of ram and unlinked the controllers. Still claims my Processor is running at 9.22 ExaHertz. Nice. Full infos, for those of you that're curious about where this FX 8120 falls over; http://browse.geekbench.ca/geekbench2/529457
I'm feeling so shamed by the Intel SB-e crowd. Then again; most of my kit is £100 cheaper than most of the Intel stuff. Simply because the motherboard isn't at such a premium for the same spec.
This thread has to set some kind of record for the biggest differential between lowest and fastest benchmarks
I think you should also feel shamed by the last generation Intel kit from before SB! Why did you go bulldozer?!
