UPDATE 09.01.2015 To mount Acrylic-tube compresssion fittings at the top of the rads , ı will to use special fittings , instead of T-plug connectors of cape cora.. I made special fittings for connection on the top. Milling and drilling with lathe And the fitting from brass all fittings ready Fitting with mounted 3x Orings R88 mounted to Cape cora for testing R89 lead soldiers are waiting to be painted Painted mat black and mouted to the CAPE CORA..
arg-ist, thats's some sweet modding of a G5 I am not sure, but your last two updates aren't visible for me :d might be on my side or on yours :huh;
To ensure the integrity of the worklogs ı use old replies and make a new free reply at the end; like the last 2 replies.to update the worklog.. There is no problem on your side and my side.
updated 11.01.2015 I want to use Cape Cora as serial .Like this Therfore ı must mod T-plug connectors of cape cora.. on the bottom.and block one side to to prevent fluid flow. I made special stop fittings from delrin and prevented flow of the fluid. this is the loop of Watercooling, with serial working Cape Cora..
update 14.01.2015 Order arrived and the fittings for acrylic tubing are ready. Monsoon Light Port 90 Rotary Angle Fittings Monsoon Light Port 90 Rotary Angle Fittings with mounted Monsoon Premium G1/4 Led Plug Bitspower Case Top Water Fill/ Trough Hole Fittings to pass trough the case EK-HDC Fittings 16mm G1/4 FOR Acrylic tubing Bitspower G1/4 Rotary 90 Adapters and some special fittings of Cape Cora
update 17.01.2015 To mount Bitspower Case Top Water Fill and through hole fittings Pre drilled And extended to 20 mm in diameter with step drill Case through hole fittings mounted to control Case top water fill for reservoir mounted EK-HDC Fittings 16mm G1/4 mounted to Bitspower through hole fittings.
UPDATE 24.01.2015 Fittings for acrylic tubing are ready and it is time to bend 16mm OD acrylics. but no free time... Fıllport for reservoir
Not to be picky, but flipping ATX around, doesnt make it a BTX which is an actual form factor for a mobo. This case is simply reverse ATX
Ofcourse BTX is another form factor. My case is ATX reverse (like BTX). Corrected. Thank you for warning.
UPDATE (1) 30.01.2015 İt is time to work with acrylic tubes. To see the difference 12mm OD and 16mm OD acrylic pipes. bending 16 mm acrylic pipe bended acrylic pipe al pipes ready and some photos with pipes mounted for test.
Ofcourse I will pay attention to the balance problem Dude... Empty case with radiator is unstable. But there are already heavy items at the bottom of the case... As PSU + HDD … I can add a little weight if they are not enough….
Hi I must choose liquid color. I plan to use as color CERULEAN BLUE . but ı cannt find CERULEAN BLUE FLUID Cann any body help me . or which color would you use with MAC G5 Case..Thanks
Hi I would go with a pastel color, not transparent. But for the color.... maybe royal blue or lapis blue? (little difference) Either way you'll need to mix the colours yourself!
I hate you! That how freaking good you are m8. This Will be one of the best Mac g5 cases ever and i have atlets seen 300 project logs on internet. //FallenFate
Mayhems ultrapure plus a single drop of their blue dye perhaps? Please don't put pastel in it. Everyone is just riding a bandwagon this project deserves more! Love the "out the box" thinking!
