Case Mod - In Progress Mac G5 Mod. arg-ist
Discussion in 'Project Logs' started by arg-ist, 25 Nov 2014.
  1. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    UPDATE 06.02.2015
    I can not decide whether use of pastel or transparent fluids.
    I think this is pastel fluid.
    I wantt to achieve this in blueish green
    With transparent fluids and dyes can ı mix and achieve Ceruluian blue
    but it not very easy to achieve cerulian with pastel fluids and dyes…
    I need to be patient…
    During the color experiments , ı mounted pump-rez combination an XSPC D5 Photon Reservoir/Pump combo
    And made connection between bıtspower case through hole fitting and reservoir
  2. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    thanks.
  3. Jeffinslaw
    Jeffinslaw What's a Dremel?
    26 Jun 2014
    Digging it so far!
    -Jeffinslaw
  4. stealth80
    stealth80 Minimodder
    1 Feb 2015
    This looks good !
  5. Zoyadog
    Zoyadog What's a Dremel?
    28 Jan 2014
    I think transparant fluid would be nice :) well done.
  6. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Thanks.
  7. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    I gave a short break due to my illness. arg-ist
  8. MODZERO
    MODZERO Minimodder
    29 Jun 2011
    Hope you're feeling better chap, looking forward to seeing more of your build.
    J.
  9. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Thank You HackJoe
    I turned again to the World…
    continue from where I left off going to study.
    Adding some photos from the case MAC G5
    I have two new MAC G5 cases on the road ..(on the work table)
    One test bench MAC G5
    And a Jumbo, double MAC G5 case
    68
    Acrylic tubing in the case ready
    a1
    a2
    a3
    a4
    a5
    The location of PSU.
    a6
    I used an old smaler semi modular PSU. And made a drawer , storage compartment , for unused cables.
    a7
    top cover, to hide cables
    a8
    and the HDD mounted over the cover with an adapter.
    A9
    I made a 7 station led board
    a10
    with on of switch.
    a11
    power cord of PSU
    a11a
  10. Icelander
    Icelander Minimodder
    3 Mar 2015
    interesting G5 Mod
  11. spunky_me
    spunky_me What's a Dremel?
    29 May 2009
    Welcome back! It has been so long ago since your last upgrade.
  12. Cheapskate
    13 May 2007
    Looking good.:D Can you sneak that switch box to the inside somehow? I think maybe mounting under a hole so the rubber button is exposed, and extending the rocker switch to face out...
    -Maybe just mod both switches so you can hide the box with the PSU cables.
  13. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Conceivable ! Thanks.
  14. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Thank you , but...
    at this time I had to modify myself… refurbished ... refurbised…
  15. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    and organizing sleeved led plug cables of Monsoon Light Port Rotary Fittings
    a12
    a13
    a14
    a15
    a16
    a17
    a18
    a19
    a20
    a21
    a22
  16. arg-ist
    arg-ist Minimodder
    21 Dec 2013
  17. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    To see the result before final
    lighting of of the acrylic tubes without fluid.
    a23
    a24
    a25
    a26
    a27
    at this time I must modify myself…and find cerulian blue...
    2 weeks late summer holiday … At Fethiye /Turkey
    You are invited too…
    and then final photos.
    Aytos likes this.
  18. bakan
    bakan What's a Dremel?
    19 Sep 2015
    Awesome... great work.
    This will be one of the best Mac G5 , ı have ever seen.
    When we ll see final photos.
  19. arg-ist
    arg-ist Minimodder
    21 Dec 2013
    Thanks bakan
    Mac G5 project is finished . I must take final photos.
    At this time ı have a new worklog... a new Mac G5 .
    MAC G5 BENCH
    Coming soon...
  20. Gramps-Makarov
    Gramps-Makarov What's a Dremel?
    11 Aug 2015
    This is just perfection, for me this is one of the best powermac G5 mods.
    Great work and stuning results.
    //Gramps
