Scratch Build – In Progress Metaversa 02: Ada
Discussion in 'Project Logs' started by Nexxo, 21 Jan 2014.
  1. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    Methinks we should make a cautionary thread in the modding forum. Would keep many of us from finding stuff like this out the hard way!
  2. Nexxo
    23 Oct 2001
    Yeah, I know all about brass swarf --it gets everywhere. Luckily Birmingham has a couple of metal dwarf recycling places.
    I'm trying to keep Ada fairly simple; I want to finish this thing sometime this year as I really need to upgrade my working rig. :)
    Once Ada is done, and I have more experience with the lathe and mill (yeah, that will be my next purchase) I will have time to do a more elaborate project that I'm redesigning (possibly around an Asus Extreme Black Edition, or its successor): Camille.
    Blame Skyrip. He felt that Ada didn't really stretch him CNC-wise, and he wanted a challenge. "You should do Camille", he said. So hopefully next year I will.
  3. The_Crapman
    5 Dec 2011
    :eyebrow:
    Razer2007 and Nexxo like this.
  4. Nexxo
    23 Oct 2001
    :lol: Swarf! I mean swarf! Damn you, autocorrect...!
  5. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    Actual pmsl. Have some rep.
  6. The_Crapman
    5 Dec 2011
    Strangely i did see a goth midget in new street station today.
  7. Cheapskate
    13 May 2007
    STONEHENGE!:rock:
  8. Nexxo
    23 Oct 2001
  9. Krikkit
    21 Jan 2003
    Nice! Love a bit of lathe action. :D
    For the fan cones, if you had them on the blades the increased rotational inertia would smooth out PWM control very nicely, and would probably make it sound better (what little noise there is).
  10. Nexxo
    23 Oct 2001
    True, but the trick would be to mount them absolutely dead centre on the propeller hub. Just a micrometre off and you'd create wobble = not good. In any case they add inertia to the motor hub and might reduce what little vibration there is. Although I don't expect them to make any difference except look pretty. :)
  11. Krikkit
    21 Jan 2003
    The way to do it would be to dismantle the fans and mount the prop on your new lathe, then you could find and mark the rotational centre etc. If you were feeling really swish you could turn the edge of the hub down a little to smooth it into the edge of the cone.
    Just for amusement of course! They look great as they are. :)
  12. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Do they pay you for your swarf like they do here?
  13. Big_malc
    Big_malc Minimodder
    7 Sep 2010
    depends what it is and if its clean or contaminated
  14. Teelzebub
    27 Nov 2009
    Looking good though Nexxo :thumb:
  15. KayinBlack
    2 Jul 2004
    Oh, what finish will you be using for your wood? I'm trialing an old, old recipe for black walnut stain and thus far it's been great, will dye almost anything, including me! If you're interested and you can't get black walnuts, I'll gather you some hulls and box them up.
  16. Cheapskate
    13 May 2007
    People buy swarf? My God! I could have been a millin'-aire by now.
  17. KayinBlack
    2 Jul 2004
    Any metal swarf they will, at least here. And pay good money for it, too. I even take off my brass and copper dust and get something for it. Been financing my archery with TV destruction-all the copper/aluminum gets recycled, the screen is separated out into glass suitable for knapping and the rest gets disposed of, less the dangerous chemicals in the tube. It's made me a pretty penny.
  18. Egami
    Egami Why is the dremel on fire?
    27 Aug 2013
    Ooooohhhhh. Just oooohhhhh.
  19. Nexxo
    23 Oct 2001
    Don't know. I was looking for an ecological way to dispose of it, mostly. Can't be worth more than a few pence.
    I'm thinking black walnut, waxed. But depending on the result I may well be wanting to try your stain.
  20. Nexxo
    23 Oct 2001
    Today, I finished the other cone. They match (phew)!
    Next step: paint the fan blades black --if I can find a way to disassemble them. Contrary to most fans, peeling of the label does not reveal a small hole in the fan casing where you can remove a C-clip and detatch the propellor from the coil assembly in the casing; I am met with a solid, blank wall. Hmmm...
