SketchUp MNPCTech Design Contest Volume 6 - Modify a Cooler Master HAF 932
Discussion in 'Modding' started by confusis, 16 May 2011.
  1. Frenkie
    Frenkie Lets mod the world!
    3 Jul 2006
    Not betting there.... all 'our' novel ideas have mysteriously found its way to the big companies without a nickel for the 'inventors'. ah well. Thats cutting edge modding for ya :)
    BTW, nice thread, stupid of me I missed this before. How about part 7: modding Mini-ITX ? :D
  2. danitgeek
    danitgeek Designer
    17 Sep 2010
    Reservoirs Added :D
  3. Cheapskate
    13 May 2007
    One contest at a time, Frenkie.:lol:
    @Danitgeek - Getting there, man.:D
    OK, Inspired by editor's orientation change. (That sounded gay.)
    -I imported this face, thinking I would delete the old one, but it freaks me out how well the two blended... I think my grandma had one of these to heat her bathroom.
  4. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I did the top panel design Cheaps, reminds me of early 60s cars :hip:
  5. zeBriukas
    zeBriukas What's a Dremel?
    25 Apr 2011
    Heh... I'm trying to learn how use google sketchup, but my pc is to slow xD anyway, i will try to do the best what i can :)
  6. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Lol I nearly ruined my keyboard from splurting out coffee when I read that! So many things i could say to that but I can't think of any that would be forum appropriate :nono:
    Your latest one re minds me a lot of Bloo ;)
    Don't have a lot of time at the moment so doing what I can when I can :) still roughing but the shapes starting to come together :D
  7. Cheapskate
    13 May 2007
    :worried: We were thinking along the same lines about underbelly venting I see.
    The purple square thing in the base is a PA140x3 model. I can't believe it's flopping around in this case like the proverbial hotdog in a hallway.
    @Bill - Yep. Inspired by the old hood gunsights. -Back when pedestrians knew what the road was for.
  8. Editor22
    3 Jan 2009
    awww and I was just working on some little spiked feet as well lol
  9. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Nice decoupling feet. You'd better have a nice though and hard surface under the case.
    I really like it, reminds me of very high end audio equipement (valve amp, full range horn speakers, etc.)
  10. mnpctech
    21 Apr 2003
    Exactly! :thumb:
  11. stuartwood89
    20 Aug 2008
    Wow this is a hard model to work with, and has reminded me how much I hate Sketchup sometimes. Not so much because of the quality, but how complex it is. All I've done so far is add another fan hole up front, and that took me the best part of 30 minutes:
    I'm not sure if I'll be continuing with this one. I'm at my decent PC at my Mum's at the moment, but at home I have to use Sketchup running on WINE on a seven-year-old laptop. I have tons of ideas, but with this case...? It's hard to polish a turd to be honest.
  12. Cheapskate
    13 May 2007
    Yep. I wanted to play with turntable spikes.:D
    @Stuart - I've found SU works differently depending on the computer. If you are having problems with it not bending to your will, it might not be your fault.
    I think that's why Confusis chose it.:lol:
    Anyway, I'm done with thisone. I can't get myself to waste time adding components.
    Optical and usb are accessible through an (undrawn) door in the face.
    -The purple orbs house non-existent micro nixie tubes that give temps 'n stuff. Gunsight is an illuminated power switch.
  13. GuilleAcoustic
    26 Nov 2010
    wow, very nice looking. Maybe you could add some kind of "wings' on the rear top (like old Cadillac)
  14. eeced
    eeced My finger is in the fan
    26 Mar 2007
    My attempt at doing som changes to the case. Used some inspiration from black stealthplanes... problem is that it isn't very black... or very stealthy either.
    How many ideas could one submit to this contest?
  15. mnpctech
    21 Apr 2003
    You can keep posting drawings, but only one can be entered as Final entry. ...Awesome drawing btw, would be sweet military or airforce theme build.
  16. Cheapskate
    13 May 2007
    Ooooh! :D
    Welcome, eeced. You will want to submit only one for the final selection. Any more and you would be competing against yourself.
    ...but you can put as many designs in the thread as you want. The more you do, the more ideas you come up with. You might build something you like even more.
    For your current: not stealthy? You might add a zig-zag layer over the side panel edges. -like the fighter cockpit.
    @GuilleAcoustic- I'm done with that one.:p
  17. danitgeek
    danitgeek Designer
    17 Sep 2010
    Radiators Each is 240mm also added 2x120mm fans
  18. mnpctech
    21 Apr 2003
    lookin good dani, no optical drives is fine with me too :thumb:
  19. k0rben
    k0rben I use my dremel as a toothbrush
    22 Jul 2010
    Does anyone have hi-res 45° elbow :worried: ? i'm almost finished
  20. Frenkie
    3 Jul 2006
    Flashed through my mind: "Dune".
