Scratch Build – In Progress Mr3D - Project Tatami (mATX computercase from scratch)
Discussion in 'Project Logs' started by Mr3D, 22 Mar 2015.
  1. shinji2k
    shinji2k Minimodder
    15 Sep 2012
    I hate you :p. Anything I do now in comparison will look like a monkey with a hacksaw made it.
  2. Cheapskate
    13 May 2007
    -Someone called me?
    Wait.. You milled DEEP woogly channels? That means you have some ridiculously tiny mill bits that also have the reach?
    -Or did you just attach a spatula to your EDM machine and go to town?
    -Awesome at any rate.:D
  3. Waynio
    Waynio Relaxing
    20 Aug 2009
    :hehe:
    Sweet block though. :jawdrop:
  4. Noob?
    Noob? What's a Dremel?
    18 Oct 2009
    Now thats one fine piece of engineering! :)
  5. Mr3D
    Mr3D What's a Dremel?
    23 Dec 2011
    Thanks guys! :D
    Wellllllll, I didn't made this, the machine did... :hip: The stuff I do is still monkey with a hacksaw quality... :D
    Yep, those flanges are milled, used a 0.5mm ball-nose mill for that. The flanges is 0.45mm wide and 0.55mm clearance(so, 1mm spacing), 3.5mm deep. Milling the flanges took around 4hours to finish... :yawn:
  6. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    I don't know what any of that means, but it results in serious nerd porn! Do you do some software-based flow testing when you're making stuff like this?
  7. Theophilus_Field
    Theophilus_Field If all else fails... use the surfacing tools
    17 Oct 2013
    *scrabbles under table to retrieve eyeballs*
    Good grief man! And I thought I liked to make billet parts :D
    I agree with Cheapskate, this thread needs an NSFW rating!
    Keep up the good work!
  8. Concept73
    Concept73 Wannabe modder.
    30 Aug 2013
    Attention to detail makes me happy, lovely log so far.
    In regards to your original post about you not liking doing build logs, I think you're doing an awesome job so far, I don't like reading loads and loads,
    good pictures with a quick sentence explaining what is going on or why you are doing it is perfect.
    Keep up the good work, look forward to seeing more!
  9. BeeP
    BeeP Minimodder
    17 Dec 2009
    The waterblock is epic.
  10. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Overkill is a way of life for the modder extreme! I love these kinds of builds. Makes me feel like a kid come Christmas time. Also, getting a little education is a damn good thing. I sub this... I...I kneel before it in worship of it's beauty! It is becoming difficult to retain my precious bodily fluids while gazing at all the goodness I have wittnessed in this log. Glory I say, GLORY :rock: hehehe this is some seriously good poop Mr3D :thumb: thanks
  11. Mr3D
    23 Dec 2011
    Yes, I did some flow simulations. No really advanced simulations, tho.
    With this simulation, I just looked for dead-spots. I'm no engineer so the values, like water velocity and such, I have no idéa what they mean. :wallbash:
    Thanks guys, I'm glad you think the worklog is just enough text/image wise. :rock:
  12. Primum Agmen
    Primum Agmen What's a Dremel?
    21 Sep 2012
    Oh damn, now I've got a sticky mess to clean up. :(
  13. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    This is next level sh*t.
    Love it
  14. Andreas | Brodholm
    Andreas | Brodholm Minimodder
    12 Jan 2013
    I like this... A lot :)
    Just LOVE the cnc work here and all that metal, damn.
    One of the best ones i have seen for sure. Keep em coming.
    Riktigt, riktigt bra jobbat!
  15. Ygd3n
    Ygd3n What's a Dremel?
    21 Jan 2012
    Daniel you are so crazy. I loved your old waterblock. But this.. Is something else. Good job mate!
  16. Mr3D
    23 Dec 2011
    Free paper towels for anyone that reads this thread! :naughty:
    Thanks man! :rock:
    Comment Attack from Sweden! :lol:
    Tack grabbar, uppskattas! :clap:
    So, time to announce a small "change" for this project. Well, it's nothing that affects the the actual build, but I've chose to give this build a name, and also announce that I've got sponsors for this build(at the time I'm writing this, only got one).
    First off, the name. Project Tatami, or for short Tatami. I'll tell you later why I've chose that name, should be around middle of the next week.
    As you might've noticed, the first post is updated with a banner and the title is also changed.
    About the sponsors, I've kept this a secret, thinking that images of the products is enough. But I realized that actually announcing the sponsors might be a better choice.
    About the build-log itself, I'm still a beginner in making the log as structured as possible, so suggestions for improvements are always welcomed.
    That should be all for the changes.
    Update about the build itself? All I can say is that on Mon/Tuesday I'll pick up the side-panels from the water-jet guy. :rock:
  17. ApheX-E
    ApheX-E What's a Dremel?
    23 May 2015
    Impressive level of build quality on this case, just loving it. I wish i had access to the equipment and tools you have there. Looking forward to seeing more on this project :)
  18. colinmcr
    colinmcr What's a Dremel?
    1 Jul 2014
    Off the wall ! Seriously jealous, makes everything I've ever done look like I went to the scarp yard and super glued some bits together.
    Kudos to you sir, stunning.
  19. Mr3D
    23 Dec 2011
    Thanks guys, more NSFW coming up! Don't tell me that I didn't warn you this time... :lol:
    How about a few side-panels?
    Huge thanks to WST for water-jet cutting the panels! :eeek:
    Side-panels were cut from a 2mm brushed aluminum sheet.
    The bottom-panel were cut from a 4mm 6082 aluminum plate. I chose a thicker plate for the bottom because of the weight from the case and feets acting on just that plate. Gives the case a more solid feel.(Like it isn't solid enough right now...)
    4mm thick polycarbonate sheets was chosen for the windows. Tho I have to do some machining on them before mounting.
    The side-panels was cut in the finecut machine, yeah. That produced some niiiiiice cuts! :jawdrop:
    ASSEMBLED! :naughty:
    I'm really happy with the result! Going to anodize the panels black, later. But silver isn't that bad, either. :worried:
    So, a close-up of one of the corners.
    As you can see in the pic, 2 of the plates alignes really good with the chamfer on the frame, but one doesn't. Well, that was just me that didn't think/thought about it. For the final assembly, all the plates will align perfectly with the chamfers.
    About the project name, why Project Tatami?
    Tatami is a Japanese floor-mat. Well, it's not the mat itself, but the pattern related to it.
    That's all for this update! Next update in a few days. :hip:
  20. Waynio
    Waynio Relaxing
    20 Aug 2009
    Awesome case mate, removing the panels just exposes more awesome. :D:clap:
