Scratch Build – Complete Na'ir al Saif
Discussion in 'Project Logs' started by Attila, 3 Feb 2010.
  1. Neji
    Neji What's a Dremel?
    3 Jan 2006
    It actually looks great. Well done.
  2. slipperyskip
    slipperyskip Member
    26 Oct 2003
    sunnyXtremist's Satella
    Maybe this is the person you are thinking of. This is some of sunnyXtremist's work. I also like the look of this kind of modded fan.
    I'm looking forward to watching this project. :thumb:
  3. Xion X2
    Xion X2 What's a Dremel?
    18 Oct 2009
    And the man who graces MDPC's latest masterpiece is already back in action. :thumb:
    Looks great so far, but I'm concerned about the weight of those hard drives hanging from the PCB and motherboard slot. You've reinforced the PCB except for the very bottom PCI-e connector which is a thin plastic. Two standard HDDs are heavier than any copper waterblock that I know of, so it would put a lot of stress on that piece.
    Have I missed it, and are you somehow able to mount through the motherboard and into the standoffs/tray? It looks like you're using laptop drives (they look smaller) so maybe they are much lighter?
    I'm amazed that you're able to get such quality out of mostly hand tools such as your hacksaw. This pic here is incredible.
  4. dakota67
    dakota67 SOUTH DAKOTA MODDER!!!
    19 Nov 2009
    Amazing work! Awesome.
  5. shakka65
    shakka65 What's a Dremel?
    17 Jan 2010
    He'ssss Back!:clap::clap::clap: When I came here today and saw that you were back modding, it sure made my day. I was very thrilled. I really enjoyed reading your logs. Your work is so good it looks factory made and not by hand. Let me say that you are definitely off to a great start.
  6. Attila
    Attila still thinking....
    22 Feb 2008
    Thanks a lot guys. :thumb:
    It turned out an easy matter to balance the fans. I have an action shot but have
    refrained from posting it due to the "safety first backlash". :hehe:
    But while I was doing this my mind drifted back to before I started making the fans.
    Back to when I was trying to source materials for making the nose. The first place I went to was the local RC hobby store because I was after those spinners they put on the nose of RC
    aircraft. This shop only had three examples and none were the right size, so I found the foam
    eggs and yadda yadda ya. Well, I decided to look further afield and found, about 35km's
    away, a really big hobby store that had a box full of spinners. Sorting through all the stuff I
    found four examples of what was needed(45mm diameter). So now all doubt has gone and
    I'm very happy with what will be possible with these.
    You have to agree these are pretty sweet.
    This project will have a color scheme. :jawdrop: So a couple of colors will be tried.
    And while the fans were being primered, colored, and clear coated, the second frame had
    to be made.
    A coat of primer after initial filling shows up areas that need more attention.
    My desk looks like a scene from "Earth versus flying saucers". :lol:
    Be still my beating heart.:hip:
  7. prettynifty
    prettynifty What's a Dremel?
    2 Mar 2010
    wicked
    Hello oldnewby,
    I loved your Cygnus X1 mod. But is looking good as well :rock:
    definitely subbed,
    Prettynifty
  8. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Oh man, what a great start! Good to see you back at it!
  9. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Awesome work. Will be watching closely
  10. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    It's simply F-A-N-T-A-S-T-I-C the way you transform common objects into special one !!!!!
    The foam easter gave me an idea :idea:
    Great modder :dremel:
  11. p0Pe
    p0Pe gief cake?
    23 Nov 2007
    you got me hooked man! that harddrive pci-e thing beats ANY Z-drive outthere in looks!
    cant wait to see what you comes up with of ideas with this one. your cygnus X1 build was mindblowing
  12. Attila
    22 Feb 2008
    I'm not really happy with theses square frames. You see the internal frame has some
    very interesting shapes and having these big, square blocks sitting on the front just
    doesn't cut it. So with that in mind I went hunting for something that comes close to the
    picture in my mind. It still has to be fat and chunky just not square. :hehe:
    And I found these PVC plumbing bushes.
    It looks quite good, with segments that look like cooling slots, and it's made from thick
    and solid material. But there are some problems. The internal diameter is only 110mm and
    the old frames have a diameter of 116.85mm. There is also a lip on the inside on one side.
    But I need to get a look at what this could look like with a fan inside. So the quickest way
    to do this is to reduce the fan diameter. So I first used an old fan.
    OK this doesn't look bad but I'm still not won over. So lets get a look at this with another old
    fan and a spinner.
    Meh! I quickly sprayed the fan silver.
    Back soon.
  13. Boddaker
    Boddaker Still hangin around
    30 Nov 2006
    Great job on the fans Attila. :thumb: Are you planning on doing anything about the stock propeller slots in the nose cones? You could easily glue in a patch and use filler to smooth it out. Although I guess they won't be too noticeable with the fans spinning lol.
    I really like the chrome trim ring in between the fan and nose tho!
  14. stonedsurd
    11 Mar 2009
    I was going to mention that too. Really like the new spinners, the sharper point is nicer than the eggshells. I still can't get over the way you've made these fans.
  15. Guest-23315
    Guest-23315 Guest
    Okay, how did I manage to miss this??
  16. jhanlon303
    7 Sep 2006
    I need to get on line more! This is quite the start. Fat fans are neat and the siding covers are a novel idea. I drop in from time to time for sure.
    john
  17. Asulc
    Asulc Minimodder
    18 Jul 2007
    Those fans look amazing... and the hard drive mounting? spectacular...
  18. Cheapskate
    13 May 2007
    Sweeeeeeet! I have to say leave the holes in the cones. It would be a waste to hide the pornographic milled aluminum.
  19. ringo
    ringo What's a Dremel?
    14 Jun 2008
    The new design design of the fan's look much better than the first one.
  20. Cleveland216
    Cleveland216 Carbon Fiber King
    30 Dec 2007
    Damn you!!! You make me want to throw my current build on the floor and start all over again. You have some great little ideas when it comes to mounting and stuff.
