I managed to break 7000 (only just) which you can see here: linky My 3570 is holding back by score as my physics scores are low compared to other 680 scores on a 3770. I am hoping to get a 3770 soon, so will give it a go again then.
I have 7.5k on my 680, have seen someone else post >8k on a single 680, so if the setup is quick and correctly setup it should put in good numbers.
The answer to my problem was so simple. Because I was on full screen the pop up box that says change from aero to basic was hidden, so that was making it crash. After that I had it running a treat, well at least up to the point where Fire Strike kicked the crap out of my 460's
Just ran it on my dad's pc and it worked fine, so I might spend some more time trying to get it running on my pc. System Spec I5 2500K @ Stock 8Gb Corsair 1600Mhz CL9 GTX 660 @ Stock Speeds MSI P67 Mobo 2x 120Gb SSD's in Raid 0 Drivers used were the 310:90 Kind of annoying that it runs on my dads but not on mine.
My attempt with sig rig below - slight OC on GPU. I can't tell whether its good or not but thought worth posting fot those who wish to make a comparision
Oh right here they are. Ice Storm http://www.3dmark.com/is/176834 Cloud Gate http://www.3dmark.com/cg/160036 Fire Strike http://www.3dmark.com/fs/162153
http://www.3dmark.com/is/196416 http://www.3dmark.com/cg/177716 http://www.3dmark.com/fs/180747 I thought the beta 313.96 drivers gave a Valid Result?
