Graphics New 3DMark Benchmark Suite
Discussion in 'Hardware' started by The_Crapman, 4 Feb 2013.
  1. damien c
    damien c Mad FPS Gamer
    31 Aug 2010
    I still cannot get this to run, have uninstalled it now so will try installing it again see if it makes any difference.
  2. rollo
    rollo Modder
    16 May 2008
    Can't get it to run under SLI myself. Keeps crashing under the final benchmark.
  3. damien c
    31 Aug 2010
    1st time I ran it, I got to the demo video for the 2nd benchmark then it crashed.
    2nd time it got, just passed the 1st demo.
    3rd time it went through the 1st benchmark and 2nd but crashed just before loading the 3rd demo.
    Ran prime etc and stressed my graphics card just to check everything is ok and it all came out fine, so I think it's just this benchmark software has a few bugs.
    Not going to buy it until I know I can run it.
  4. RichCreedy
    RichCreedy Hey What Who
    24 Apr 2009
  5. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
  6. flamin9_t00l
    flamin9_t00l 1,000,000,000,000 Bytes Free!
    4 Jan 2010
    I noticed the whole 1.5GB vram was maxed at some point during the benchmark.
    Check out the manufacturing technology lol :jawdrop:
  7. Harlequin
    Harlequin Modder
    4 Jun 2004
  8. law99
    law99 Custom User Title
    24 Sep 2009
  9. sandys
    sandys Multimodder
    26 Mar 2006
    Seems like running valid Nvidia drivers gives you quite a bump in performance in fire strike, so perhaps the people with problems need to run the betas.
  10. rollo
    rollo Modder
    16 May 2008
    Can't see me installing beta drivers for 1 benchmark. If it effected any game that I played I'd probably upgrade but ill just wait for those drivers to go to release I think.
  11. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    2500k and an MSI 670 Power edition both at stock.
    Dont know why it says my ram is at 667 when it's actually at 936.5, also I'm getting the invalid driver crap as well, don't think I've ever ran a 3dmark bench that actually approved of my drivers.
  12. damien c
    31 Aug 2010
    Well I have been up since 5am this morning, and I have tried all sorts to get this to run.
    Tried the following things:
    1: CPU at stock speed
    2: CPU underclocked
    3: CPU overclocked
    4: Fresh install of windows 7
    5: 4 different graphics driver versions
    6: None SLI
    7: SLI
    8: Overclocked GPU
    9: Stock GPU
    10: Underclocked GPU
    11: Fresh install of Windows Vista
    12: Fresh install of Windows 8
    13: No motherboard drivers
    14: Installing 1 motherboard driver at a time and running it after each driver install
    15: Different PSU
    16: Different CPU
    17: Different Motherboard
    18: Different GPU
    19: Different Ram
    20: 3D Mark installed on Corsair SSD
    21: 3D Mark installed on 2tb Samsung HDD
    22: 3D Mark installed on 1tb Seagate HDD
    23: Windows install on USB Pendrive
    24: 3D Mark installed on USB Pendrive
    25: Different sound card
    26: Different sound drivers
    27: No Sound Card
    28: No graphics cards except the onboard
    Every single time it, will crash at different points through out the benchmark run and always ends with either a image on the screen frozen or a pure white screen, and when you do the old CTRL+ALT+DELETE the screen just goes Black and you have to hit the reset button.
    Prime 95 ran for 24 hours solid, Memtest ran for 2 passes, Heaven Benchmark ran for 10 benchmark runs, Older 3D Mark test's ran for a minimum of 10 times, Furmark ran for 8 hours.
    I just cannot get this new benchmark software to run.
  13. Harlequin
    Harlequin Modder
    4 Jun 2004
    oO my 7870 gets a higher score and my phenom gets a better physics score than your i5
  14. damien c
    31 Aug 2010
    One thing I have not tried is the Steam version so I am going to try that now.
    **EDIT**
    Steam version didn't work either
  15. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Do you mean just on the last test?
    I'm using older drivers so not sure how much difference that makes, might try the others just to see.
  16. Harlequin
    Harlequin Modder
    4 Jun 2004
    only the beta drivers are approved curnetly , but the last set give comparable results
  17. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I'm using the set before the current ones as I read somewhere that people were having issues with the lastest.
  18. Kovoet
    26 Aug 2009
    Tempted but will not use beta drivers
  19. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    Well I've been messing about for a while and this is the best I can get.
    Ice Storm: 186987
    Cloud Gate: 20283
    Fire Strike: 7033
    I've used the latest beta drivers and to be honest, I haven't had an issue at all with them.
    My graphics scores are ok for a single 680, but my physics scores are holding me back.
    Is it correct that the physics scores are CPU dependent?
  20. Harlequin
    Harlequin Modder
    4 Jun 2004
    aye they are
