Graphics Nvidia SLI crashing. - Finally Fixed!
Discussion in 'Hardware' started by .//TuNdRa, 15 May 2012.
  1. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    This is so much goddamn ********. Why the **** does this card work one minute, then go to **** the next, also; why the **** does it hang windows startup so much? That doesn't even touch the GPU apart from driver initialization. But no. With no friggin cause; The entire ****ing machine has gone to **** again. TO make things better; I can't even get Windows Performance Analysis tools to install so I can see what the **** is going on at startup.
  2. jizwizard
    jizwizard Modder
    24 Dec 2010
    still want me round tomorrow? I've got sli 570 you can try or sli 670, the choice is yours lol
  3. .//TuNdRa
    12 Feb 2011
    I'll keep toying. I should get back to you in an hour or so. I'm just trying to nail down the source of the problem. It's either windows or motherboard based. I'm more inclined to think windows now, simply because every time I tear the machine down; all my USB stuff gets plugged in in different locations, so it has to redetect all that, during which time SLI works. I reboot and it loads up all the drivers, SLI goes down the crapper. Followed by my patience and possibly the whole PC.
    I'll reinstall the 301 drivers (As they actually let me enable SLI), then intentionally reboot with the extra boot logging tools in the Windows Development Kit running, see if that churns out anything interesting, like why the balls the system hangs for so long on boot.
    If I can pull anything interesting from that; I can crucify the files at fault (Oooh~ I wish!) or remove the device responsible, then try again and see what happens. From then on; I should get lucky and get it working consistently again.
    I can hope, no?
  4. Fat Tony
    Fat Tony Minimodder
    3 Jul 2009
    If it's a windows error - then it may be being caused at install - memtest86 your ram, test your PSU, error check your HDD.
    Treat it as a new build, suspect eveything
    Failing that, I have some 1366 bits and bobs up for a reasonable price ...
  5. .//TuNdRa
    12 Feb 2011
    Ram is running at above rated timings, (As in, I think it's made for 9-9-9-28, It's at 9-9-9-35 because I can't remember the exact specifications.), PSU is fine. Even at absolute max; this rig can't touch 800W, 1KW is overkiill, Plus if it was a PSU issue; It wouldn't occur every other bootup. It'd be more consistent.
  6. Fat Tony
    Fat Tony Minimodder
    3 Jul 2009
    Understand what you're saying Tundra, just exploring the possibilities.
  7. .//TuNdRa
    12 Feb 2011
    Just pulled out the USB3 device too. no change. One of the 550's is sharing IRQs with the USB devices, but they're the 2.0 stuff that runs everything else on my system, so it's just not going to work if I disable those.
    THe other is sharing IRQ's with the sata controller, which really isn't going to fly if I have to disable that to get it to work.
  8. Burnout21
    Burnout21 Mmmm biscuits
    9 Sep 2005
    Major sympathy for you dude.
    I guess you've tried both cards in PCI-E2.
    Can you get the machine to boot with both cards with no SLI enabled and check the output from the cards with your screen or better still a 2nd screen.
  9. .//TuNdRa
    12 Feb 2011
    2nd card will display, but it stutters. Almost as if the PCI-E bus is holding it up. Weirdly, the times when I do get SLI working; its fine. I'm not sure sure if the stuttering is caused by windows or motherboard issues, though.
  10. Parge
    16 Jul 2010
  11. .//TuNdRa
    12 Feb 2011
    Already sorted. I had that issue with steam a while back, already updated the bios, one of the first things I tried when it all started to go to pot.
    Cheers for the idea, though.
  12. Jester_612
    Jester_612 "Jammy..."
    14 Nov 2011
    Don't let that put you off - that stuff is not for beginners!
    Have you seen this?
    Also, tried ancient drivers, like 285.*? Apparently there has been a realtek driver conflict, and someone had a conflict with a Kningston usb 3 stick. http://hardforum.com/showthread.php?p=1038469173
  13. kenco_uk
    28 Nov 2003
    I realise it's a ballache but try re-seating the cpu/hsf again, i.e. take the cpu out, check to make sure there's no paste in the socket or on the cpu pins and give the socket a blast of air. Check the paste when you take the hsf off - has it spread ok?
    Seems to me it could be down to a faulty mobo :/
  14. .//TuNdRa
    12 Feb 2011
    Not using Realtec sound. It's disabled in BIOS. Drivers were never installed because I had my Xonar DX before I installed windows, so that shiz got disabled the instant it appeared.
    I'm giving 290.something drivers a whirl at the moment, albeit only with a single card at the moment, because it was getting a pain in the ass just to get into windows to solve the issue.
    I've already reseated the CPU, no bent pins, no tim in the socket, good thermal paste spread.
    I'm not 100% sure it's the Mobo, though. I'd've thought the issues would be more consistent than they are if it were the mobo, it's only if I try and boot with SLI enabled that it fails. And sometimes it hates on me enabling SLI from within windows, but that seems far more random.
  15. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Tundra, the only thing other than to test with a different PSU I can think at the moment is to check in Bios if IOMMU is enabled. It should be disabled. It doesn't freekin' work! .. as in "ESXi won't even boot with it enabled !!!111 pffss.."
    @shirty
    I have an Asus GTX260 (216) TOP, factory overclocked to 650MHz. A very good card for it's generation. It runs very quiet and can run all the games I play at the 4:3 resolutions my Trinitron can display. My only concern with it is that once I go to a new 1080p monitor, it will struggle too much and force me to play everything with the lowest details.
  16. Shirty
    18 Apr 1982
    Well if you have an SLI capable PSU and mobo you can pick up another 260 for peanuts, worth a punt before you upgrade properly...
  17. Chicken76
    10 Nov 2009
    In what games do you guys usually encounter problems with SLI?
  18. Shirty
    18 Apr 1982
    Probably kinder to start a new thread about SLI performance rather than derailing Tundra's any more ;)
  19. .//TuNdRa
    12 Feb 2011
    Admittedly; IOMMU is enabled, but it was enabled before I had any of these issues, or does 295 and onwards start to fail because of it?
    As far as SLI performance goes; Most games I've tried work with it. Occasionally I have to run a game without Vsync because of microstutter (Dunno how that works, less load should = less stutter, no?), but otherwise; I've not had any issues. Save NFS:The Run being a little beech and hating SLI. But just adding most stuff to NVCP sets it up automatically to use SLI or not.
  20. Burnout21
    9 Sep 2005
    I am seriously starting to think you've got an unstable PSU, is the system rock solid with just one card in either of the PCI-E sockets?
    Half the time PSU's will boot the machine when cold but as they warm under the load can become unstable, same with all electronics.
