Project Black Narcissus: 2006 FIN:
Discussion in 'Project Logs' started by modsquad, 28 Jun 2004.
  1. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Ordered from http://www.metalsdepot.com/index.phtml
  2. modsquad
    27 Feb 2004
    I like the wheels..
  3. modsquad
    27 Feb 2004
    Radiator
    I had a little time on my hands tonight so I installed the finished radiator in BlackJack.
    My aim was to check the Radiator's top fitting for tubing clearance with the sloping inside panel of the Lian Li. I was thinking about drilling a hole in the area for the tubing to pass through.
    It looks like it will not be necessary, more than enough room.
    Check out a front view with the stainless hex-head mounting bolts. The 5.25" bay area will also have more of the same bolts holding a acrylic cover for that section.
  4. irsekz
    irsekz What's a Dremel?
    23 Feb 2004
    That really is an awesome case i cant wait to see how this turns out
  5. mrplow
    mrplow obey the fist!!
    5 Sep 2001
    Looking great. KEEP THE WHEELS!
    Apologies for my earlier posts btw... I wasn't "slamming" the innovatek products, they're good stuff.
  6. Firehed
    15 Feb 2004
    I like it too. It really fits there nicely :)
    I did have one question (to any V-series owner, v2000 if possible if they're not the same in this manner) regarding the hard drive mounting system that I wanna ask before I forget... in the one picture I've seen of a HDD installed it's set up so all of the cables would be facing the window side. I know they use those wierd screws to mount them in the racks... I wanted to know if there's enough clearance (or how much there is) for the drives to be facing the other way (cables towards the left side panel, nonwindow side) and not destroy the cables. (I hope I don't need right-angle SATA cables... I have so many normal ones and right angle ones are expensive :wallbash: )
    Anyways...
    I was thinking you may wanna try replacing those front bolts with black ones if you can find them, however I think the silver bits really add a surprising amount of interestingness to the front panel :)
    Hmm.... for some reason I thought you'd be using bigger tubing. I like the look of the smaller stuff though, hopefully it won't make much of a difference in performance.
  7. Stang_Man
    Stang_Man What's a Dremel?
    14 Jul 2004
    real nice! :thumb:
  8. modsquad
    27 Feb 2004
    Sorry for the slow response. I can't help you with any information on the stock HD mounting clearance, as removing it was one of the first things I did, but I would agree it looks close.
    I actually tried black bolts first, but the stainless adds a little contrast to the area. The 5.25" bay area will have more of the same bolts (working on that soon).
    Honestly, I am only familiar with Innovatek and Aqua-Computer gear, but from what I have read most German H20 gear is "small-bore" like mine.
    This is a interesting thread on the subject. "US vs German systems- advantages/disadvantages"
    http://forums.procooling.com/vbb/showthread.php?t=9649
  9. Carbon
    Carbon Banned
    8 Jan 2003
    yay...finally read the whole log, i like it loads :D
    i must say that i do prefer the black case to the silver version :)
  10. hmekk
    hmekk What's a Dremel?
    17 Jul 2004
    :D there are two exacly the same pics :D
    can anyone find them :D
    btw : really nice mod :dremel:
  11. PankyBoy
    PankyBoy What's a Dremel?
    6 Aug 2004
    extremely nice looking stuff !!!
    But the consept is still the same, a "case" a "water colling" a "..."
    When I want to see something "NUTS" !!!!
    I think that moding should go beyond the standard "case" &"water colling"
    It MUST GO "NUTS" !!!!!!!!!!
    See ORAC3 for example :clap:
  12. Firehed
    15 Feb 2004
    Yeah, but I won't show it :) Scavenger hunt for all of you.
  13. f U z ! o N
    f U z ! o N What's a Dremel?
    1 Feb 2004
    but not everyone has the taste for an all out go wild case. some people just like nice, sleek and elegant cases which this one is.
  14. Firehed
    15 Feb 2004
    *raises hand in agreement*
  15. modsquad
    27 Feb 2004
    When I started this project "Black Jack " was just a working name. I think I came across a better one.
    Black Narcissus
    I was watching TV and the old (1947) movie of that name was on. Later I did some research on Narcissus from Greek Mythology.
    Son of the River Cephissus. He discovered his image in a pool and fell in love with himself. Being unable to find consolation, he died of sorrow by the same pool. Seem's aptly named for a H20 cooled computer. I just wanted to give people following the thread a "heads-up" before I rename the project.
    I have been playing around in Photoshop with front panel images and I do not like the look of my toggle switches in the 5.25" front bay. I tried every configuration and they all mess-up the clean lines of that area. So, I am going to mount the two switches for my CCFL on the bottom of the case (accessible from the side) using rocker-type switches. The only gear in the front bay will be a DVD burner and my Aqua-Computer Aquaero VFD. The hole area will be covered with a Red or Smoked acrylic panel. I should have some "stuff" comming soon, so look for updates on BLACK NARCISSUS
    MS
  16. Firehed
    15 Feb 2004
    I was going to say... the pics looked familiar but I couldn't remember anything with that name... you really got me confused! :miffed:
  17. modsquad
    27 Feb 2004
    What do you think of the new name?
    I know it is better than this one.
    http://forums.bit-tech.net/showthread.php?t=63872
    Or, you know what maybe he is correct. I love that thread..
    MS
  18. TheCleaner
    TheCleaner Back again...
    5 Jul 2004
    black jack rolls of the tongue nicely.. but when i say the new name, i unconciously start a string of sus's after the word.. so it sounds like this
    black narcissusssusususususs
    literally.. if no one has already claimed the name, keep black jack.. not many people know greek mythology
  19. Mosha
    Mosha What's a Dremel?
    31 Jul 2004
    C'mon wheres the update?
  20. Firehed
    15 Feb 2004
    This one looks better in writing, black jack is hella easier to say. I like them both though.
    I agree... I won't even read that thread because I'm imagining a litter box mod or something.
