Project Fibonacci Sequence
Discussion in 'Project Logs' started by Pfaffen, 5 Jun 2007.
  1. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    Looking good!
  2. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    the gold leaf in those thin slots looks hot :jawdrop: i think i'll have to do that to the legs of just about every piece of furniture i have one day!
  3. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    Computer parts are in :clap:
  4. Pfaffen
    18 Mar 2007
    Most of the pieces are finished...
  5. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
    One last thing to do, maybe... Etch the plexi with the old magic formulae of ( 1 + sqrt(5)) / 2
  6. Pfaffen
    18 Mar 2007
    I was thinking of "fn = fn-1 + fn-2 with f1 = f2 = 1"
  7. widmod
    widmod Minimodder
    9 Oct 2006
    :jawdrop: i want them :jawdrop:
  8. Teyber
    Teyber ******
    18 Mar 2007
    what processor is that?
    this is looking a lOT better then i thought it would be
  9. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    awesome!:thumb:
  10. Pfaffen
    18 Mar 2007
    Intel Core Duo E6600
  11. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    nice pick on the CPU, great looking case too
  12. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    That gold leaf is looking most excellent.
  13. DeltaFX
    4 Aug 2006
    Yep, that's both side of the same coin. Either you give this formula (the fibonacci sequence itself) and let ppl figure out where the gold number lies in it, or give the gold number formula, and let ppl try to remember what ties the formula to the design.
    Anyway, that a wonderful job you did :rock: :thumb:
  14. xpc
    xpc What's a Dremel?
    26 Jul 2006
    wow amazing workz! very nice job mate!
  15. s_q_u_e_e
    s_q_u_e_e What's a Dremel?
    10 Oct 2003
    The gold leaf turned out great, on the panels and in the slots =)
  16. Pfaffen
    18 Mar 2007
    Gold Bars
    Access door.
    Here is the access door. It is based on the golden angle (137.51')
    There are 8 gold leafed walnut pieces "Gold Bars". They are 137.5' from the last in the sequence.
    So... Starting from the top is #1, then 137.5' is #4, then #7 then #2, then # 5, then #8, then #3 and lastly #6.
    1 4 7
    2 5 8
    3 6
    The wood is MDF board. I stained it with the antique walnut and then used papertowels to create the streaks (grain). Once it was dry, glued the "Gold Bars" on and sprayed the whole thing with 12 layers of clear coat.
  17. Pfaffen
    18 Mar 2007
    Here is a shot of the motherboard side.
    And from the other side
    And lastly the is the front. The clamps are on to hold the DVD Deck in place. I had to align the DVD with the slots in the front. Turns out I only had 1/32 of an inch of clearance on the top and bottom. (just the way I planned it :))
    Next steps are to cut the holes in the back, for the MOBO and the PSU. I also have to cut the slots for the cards.
    Any suggestions. I have been using my Dremel on about 4 setting with a spiral cutting bit following a guide fence. Works ok, but it is slow and tedious...
    More to follow...
  18. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    I like the look of the wood and the gold leaf. Also the texture on the gold leaf panels looks really nice...
  19. csharp
    csharp What's a Dremel?
    12 Jun 2005
    When you have Core2Duo E6600 and 7600GT, you dont get all the benefits of CPU because GPU ain't so good :/
  20. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    There "ain't" nothing wrong with that GPU.
    Congrats. on being featured Pfaffen.
    H.B.
