Case Mod - In Progress project [Leonidas Beard]
Discussion in 'Project Logs' started by do}{tor, 9 Jan 2013.
  1. do}{tor
    do}{tor What's a Dremel?
    21 Dec 2012
    "Tonight we dine in hell"©
    System:
    CPU: Intel i7 3960ES
    MOBO: ASUS Rampage IV Extreme
    RAM: Corsair Dominator Platinum 4*4Gb
    SSD: Crucial M4 128Gb
    HDD: WD 1*640 CB; 1*1,5Tb CG; 1*2Tb CG
    VGA: 3*GTX 580 1,5Gb
    Sound Card: Creative X-FI Titanium HD
    PSU: Corsair AX1200
    CASE: CaseLabs M10 + Extended top + Pedestal
    _________________________________
    Water:
    Rad#1: TFC MONSTA Extreme
    Rad#2: TFC MONSTA Lite
    Rad#3: TFC MONSTA Lite
    Rad#4: EK-CoolStream RAD XT (360)
    Pump#1: DDC 1T
    + EK-DDC Dual TOP
    Pump#2: DDC 1T
    CPU block: EK HF Nickel Plexi
    VGA block: EK-FC580 GTX Acetal+EN
    FANS: Noiseblocker BlackSilentPRO 140mm, 1700rpm
    CONECTORS: Monsoon, EK, Bitspower
    LIQUID: Mayhems Blood Red
    CONTROL: Lamptron Touch, Koolance TMS-200
    I welcome you comrads! I write to you from the cold mother Russia :brrr:
    At once I ask me to forgive for my English, but I promise to try diligent :D
    The idea on creation of this project arose in me very long. Initially everything was planned to make with the Cooler Master Cosmos PURE case, but for a number of reasons, work was constantly postponed. And once I was lucky to take hold from CASE LABS, namely M10 in white color:clap: To it were bought in addition a pedestal and extended top
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Chief assistant always nearby:D
    Also the period of long thoughts at the choice of a project subject came. Options was much, but everything united them availability of blood, a large amount of blood:worried: So I came to a subject of droppers, tubes, and other hospital attributes, but what there was my disappointment when I casually came across one of the projects of the present most beloved by me, namely the White Silence project :waah:
    And again I fell into the abyss of thoughts...:grr:
    Then I was come to mind by idea to devote the project of Slavic mythology. At detailed studying of the weapon of Slavs, I started finding certain similarities to a cold weapon of ancient Sparta... and here upon me dawned...HERE IT, I exclaimed! IT IS SPARTAAAAA!!!:D
    Then received a clip from the beloved wife for shouts in the middle of the night :D
    The history about 300 Spartans is one of my darlings, and how it was shown in Zack Snyder's movie of "300" adequately loud applause:clap:
    I several times revised the movie, finally like idea and started a choice of the most spectacular moments, for the purpose of sketch creation.
    And I came to 3 options:
    1. [​IMG]
    2. [​IMG]
    3. [​IMG]
    The third since there is more than dynamics and action was chosen.
    Well and because my friend is engaged in an aerographics I was allowed to his equipment and work began:
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    In parallel with drawing, the lateral window was transferred to a laser engraving, here that appeared as a result:
    The photo in a subject will be more better a bit later:thumb:
    And again painting...
    [​IMG] [​IMG] [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    If very long not to leave the room it is possible to catch very qualitative hallucinations:naughty:
    By the way, I decided to paint everything, a fitting's, water blocks, radiators, painted everything that came to hand... the cat managed to evade:D
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    In intervals between painting I entertained myself clothing of wires:
    On fans stickers with the "300" logo were made:
    The hardware assumed to an upgrade:
    And again case...:dremel:
    With each portrayal the case starts coming to life, and it is all the second varnish coat:D
    I couldn't avoid a blood subject:
    Now I solve a problem of installation of tanks and I sew wires:
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    By the way here the established lateral window so looks:
    The computer configuration, all stuffing and components of cooling I will add a bit later, unfortunately very much there isn't a lot of free time:thumb:
    All of happiness:D
  2. Sn00k3r
    Sn00k3r What's a Dremel?
    7 Apr 2011
    niiiiice Airbrushing :D
  3. do}{tor
    21 Dec 2012
    Sn00k3r
    thx :D
    Just the friend came around on a visit, brought gifts, I love such unexpected visits :baby:
    [​IMG] [​IMG][​IMG] [​IMG]
  4. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    I loved that caselabs case as stock,
    what youve done to it is brilliant!.
    cant wait to see all the internals in!
  5. do}{tor
    21 Dec 2012
    OcSurfe
    As on me, so CaseLabs does excellent cases, but for me they as a blank sheet as a panel, it is possible to do anything, the main thing is the imagination and "straight arms". Here I also decided to add in it a little the inner world :hip:
    And any brilliant demands a facet :dremel::D
  6. ALS
    ALS Minimodder
    13 Jan 2012
    У Джеральда Батлера просто эпические роли получаются.
    Пока что с экранки, но смысл, думаю, понятен )))
  7. do}{tor
    21 Dec 2012
    ALS
    :D:waah::D
    It is a little new things. Normally to test it didn't turn out since DDR isn't compatible on height to CM V10 :wallbash:
    Well and some samplers of a logo and holders of the tank:
    [​IMG] [​IMG]
    My chief assistant constantly watches me :hehe::worried:
  8. do}{tor
    21 Dec 2012
    On days off continued to be engaged in production of holders. As the computer in the sorted condition should be drawn in the old manner. I will make some options, I will leave that will be pleasant more.
    As faced a small problem when fastening tanks, it is necessary to think how to connect them to the top radiator:
    They will be connected in parallel among themselves from above and from below by means of сristal-links:
    [​IMG] [​IMG]
  9. Si_the-dude
    Si_the-dude Techaholics Anonymous. 0 days clean
    17 Dec 2012
    Sub'd, can't wait to see more! Looks awesome!
  10. patara
    patara life is wonderful
    7 Apr 2012
    do}{tor Hello I am glad to see you,very interesting work,too it is very interesting that will turn out
  11. AciD_RaiN
    AciD_RaiN What's a Dremel?
    29 Jul 2012
    Very nice airbrushing :)
  12. do}{tor
    21 Dec 2012
    patara
    I am glad you to see too! I hope it will turn out to realize all ideas! :dremel:
    AciD_RaiN
    thx:D
    I decided to polish bp for CPU, here result of an hour of work
  13. patara
    7 Apr 2012
    work very interesting when there will be the following party of a photo?
  14. do}{tor
    21 Dec 2012
    patara
    Now I waiting for the remained components for final assembly, approximately plan to finish assembly on the first week of February, the test for a leak and the first inclusion there will be carried out, and after it there will be an organized professional photoset. Now, as you see, I am engaged in any trifles, I will cut today the controler of fans :dremel:
    patara likes this.
  15. Nikkop
    Nikkop What's a Dremel?
    16 Jan 2012
    THIS IS MADNESS!
    Madness? THIS IS PURE AWESOME!
  16. Cheapskate
    13 May 2007
    :lol: Bloody awesome!
    Cat:
    1= "Don't paint me!"
    2="put the brush down..."
    3="Don't even try it!"
    4="I said, Don't paint me!!!"
  17. do}{tor
    21 Dec 2012
    Nikkop, Cheapskate
    :hehe:
    Hmm, I didn't expect that with placement of tanks there will be any difficulties, but so even it is more interesting :dremel:
    By the way here such here clip-on earrings turned out, made for the future of 8 mm of plexiglas
    [​IMG] [​IMG]
  18. do}{tor
    21 Dec 2012
    The panel for fixing of couple of tanks with a logo, and as a substrate for the TMC-200 controler was made
  19. do}{tor
    21 Dec 2012
    Few new photos
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    :rolleyes:
  20. GotMod?
    GotMod? What's a Dremel?
    3 Apr 2012
    That's bloody awesome!!!:thumb
    Keep up good work!
