Case Mod - In Progress project [Leonidas Beard]
Discussion in 'Project Logs' started by do}{tor, 9 Jan 2013.
  1. patara
    patara life is wonderful
    7 Apr 2012
    I with not patience wait for the end result
  2. AverageNinja
    AverageNinja Almost an EpicNinja
    6 Aug 2012
    Really liking the paintjob mate! Keep up the good work!
  3. do}{tor
    do}{tor What's a Dremel?
    21 Dec 2012
    Hi, everybody! I ask to forgive, for long absence, to it I am not strongly glad. I assembled the system, about 20 hours I drove on leakages, all apprx. I started, now the processor works for 4500 Mhz at 1,39V. Further replacement of EK XT by Alphacool NexXxoS Monsta 360 - White Special Edition, laying of wires, work with lighting. For now that turned out today:
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    All of happiness!
  4. Shurika
    Shurika Minimodder
    9 Mar 2012
    Nice to meet you here, doc! Awesome project, wait for new liquid ;-)
  5. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Excellent project do}{tor! Thanks for sharing! :D
  6. do}{tor
    21 Dec 2012
    Shurika
    Editor22
    Thx! It is a pity that process was dragged out in connection with failures in delivery services, I still waiting for 8" the screen which has to take the lawful place in a pedestal and on which will be am brought information on system work from Aquaero.
    And slightly new things:
    [​IMG] [​IMG][​IMG] [​IMG] [​IMG] [​IMG]
    Be happy:clap:
  7. do}{tor
    21 Dec 2012
    Hi, everybody! With the birth of the Son:clap:, work should be suspended, but there will be a continuation soon, and now there is some photo.
  8. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Congratulations :thumb: and can't wait to see this progressing! :rock::clap:
  9. do}{tor
    21 Dec 2012
    :clap:Thanks!
    I found a little time and was engaged in the screen.
    For installation at necessary height, I cut out a small slice of red plexiglas:
    On a contour, previously having degreased a surface, I glued a construction bilateral adhesive tape. Holds very strong!
    Further was engaged in a chip:
    I marked, I did openings, I twisted legs:
    [​IMG] [​IMG]
    I fix a chip:
    Done! :D
  10. do}{tor
    21 Dec 2012
    I made a cap on ports and I started doing light panels:
    At wires and their laying you don't look, all in process.
    Light panels are almost ready
    The first substrate on grills is ready
  11. Boorach
    Boorach Minimodder
    16 Feb 2013
    What an attractive build. Your airbrush work is terrific.
  12. do}{tor
    21 Dec 2012
    Boorach
    Thx, dude :D
    And one more is ready :dremel:
