Case Mod - Complete Project: Mini Metis Maximus (ITX X99 watercooled)
Discussion in 'Project Logs' started by Combatus, 6 Oct 2016.
  1. Vault-Tec
    30 Aug 2015
    They used to sell it at Wally World (Walmart). They were small cans though, and you needed to buy every stage or it would turn out bad. But they did their full Chameleon range which IMO is the god of flips. They did their Candy range too, tangerine was incredible.
    Seems they have the Shimrin range available now.
    Jammy sods. I've used an awful lot of paint over the years but HOK had the most ridiculous finishes and clears out of all of them. Their clear was like glass.
  2. Combatus
    16 Feb 2009
    Yeah I'd kill for a decent rattle clear. They all dry pretty soft and need hundreds of layers. This mod with the marble effect was even worse. I practically used a whole can just for the front and roof panels! Air brushing is different - as B.neg says we have some good stuff over hear, although you need the gear for it.
  3. Vault-Tec
    30 Aug 2015
    PS2 using HOK cans.
    And the stand using their blue flake.
    Yeah Dan is right, there are some wicked paints here it's just that finding them in cans is really difficult.
  4. Combatus
    16 Feb 2009
    Where'd I get to? Ah yes the fan grille. So, that plastic thing I used in the concept build wasn't really cutting it, so I decided on something a little fancier! Mnpctech Billet Pro-Line 140mm adjustable. Looking at it I should probably have just got someone to CNC the side panel but once I've trimmed the blow hole back and fixed it in place I'm sure it will look great.
    The rubber feet serve a purpose on the stock case, but I wanted something to raise it up a little more and add some chrome to the exterior. Thanks again to Mnpctech - mini ITX grooved aluminium case feet! Perfect!
  5. B NEGATIVE
    B NEGATIVE All Hail Kim Jong Magoo!
    8 Aug 2011
    Let me help you with the paint...
    http://www.specialistpaints.com/
    2k clear in a can and its good stuff. I use them a lot for gun colours.
    If you have a compressor and gun then you can try...
    http://www.jawel.co.uk/index.php?main_page=index&cPath=122_184&zenid=9d53k13m2vgppi65io3cj2baa2
    Their non iso 2k is amazing.
    They also do HoK but unless you have the kit and expertise to shoot it correctly then its no better than any other paint tbh.
    Also,while im in the helpful mood,when spraying panels flat instead of hung, prop the piece up on some bent alu or angle bar so its clear of the table then wet underneath it,it catches the dust and paint so you dont get an updraft of crap onto your lovely panel. That marble looks really tidy btw.
  6. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    That paint job is bloody fantastic!!!
  7. Combatus
    16 Feb 2009
    Ta very much chaps :)
  8. Combatus
    16 Feb 2009
    God I had to delve deep to find my own thread. Has it seriously been nearly two months! :(
    Anyway, A few final bits arrived so I'm now finalising the water cooling and doing a test fit. Some mini-ITX pr0n for you :)
    Also a little upgrade from the 'paltry' PM961, which was already a spectacularly awesome bit of kit - Samsung got wind of the project and chucked a little something my way. The label certainly looks better...
    And I might have made a waterblock for it :) Not finished yet. I think I'll 3D print a little shroud or something.
    More soon hopefully!
  9. David
    7 Apr 2009
    Damn, that's pretty!
    I wish Samsung would chuck a little 1TB something my way too! :lol:
  10. Vault-Tec
    30 Aug 2015
    Go to your profile and click on threads :D that's how I find mine.
  11. Cheapskate
    13 May 2007
    M2 waterblock: :thumb: GOOD call! Those little buggers get way too hot.
  12. Elusid
    Elusid What's a Dremel?
    22 Nov 2016
    That turned out great! I always love small water cooled rigs. You packed a lot in there!
  13. Bartacus
    Bartacus Minimodder
    30 Oct 2014
    Yup, been reading that lately. It's even worse for the bigger drives because of that stacked NAND.
    Great idea! :rock:
  14. Combatus
    16 Feb 2009
    Last delivery today for the final bits for the build. Not entirely sure how I'm going to fit this lot into this case but hey ho! I do like Alphacool's latest chrome rigid tube fittings. They're very yummy.
    Also - Aquatomputer Laing DDC top - basically because it's the smallest one around with a flat top. It's literally down to the millimetre in the case so every little helps! Sadly, just not enough room for an attached reservoir either, which is a pain. The plan is to create custom polished metal plates for the pump top and also a 3D-printed shroud too.
    But! It means I get to make my own! :D G1/4in tap here we come...
    Finally, replacement screw set for Metis, this time in bare metal. Can't be having the stock black ones!
  15. C4B12
    C4B12 Minimalistic PC's
    6 Oct 2011
    Just..... wow! I love SFF stuff and this is just awesome. This and Laine's Metis build is really cool in different ways.
  16. Vault-Tec
    30 Aug 2015
    Good going A. With my Metis I bought a hole punch and then punched out some circles of vinyl to put over the screws..
    Those are great pumps I have one of those :) Love the top too. I think Watercool and Aqua make the best looking gear atm.
  17. Combatus
    16 Feb 2009
    You know, I was thinking along those same lines! I was thinking about those push-in rubber things you can get for screws. Using a hole punch and vinyl is genius!
    We'll see - I may do something similar at the end. The only trouble is to get either the motherboard or GPU out, I need to part dismantle the case so having screw covers might prove tricky :)
    I nearly got the Watercool one actually! This one was cheaper :) I would have gone with that one if I was leaving the top exposed, though, but I'll be making a chrome plate for it.
  18. Combatus
    16 Feb 2009
    Thanks! Yeah I said to him we should have them side by side at some point as they're so totally different. He's making me wish I'd laser cut the panels too but we'll see. I can always make another next year. Although I think he's cheating and having the PSU externally - it's all internal for me, although I bet he has way less stress! ha ha!
  19. Combatus
    16 Feb 2009
    I have some updates! I want to include a reservoir in the roof next to the graphics card but the trouble is fitting your average 50mm/60mm wide res up there will be extremely tight. No option to use a pump res either - just not enough room. So I thought I'd have a go at making one. I've done it before so as long as some extensive leak testing doesn't reveal any issues, it should work fine. I got everything cut to size so all that was left to do was tap the threads and glue it together. However, I have ordered some parts for an old Phobya reservoir I have that has some chrome details that are more in tune with the build so this may all come to nothing. We'll see!
    I'm thinking I'll need some kind of anti-cyclone plate so seeing as I ordered a couple of spare end caps, I'll just cut one to size and use that. It will be a low flow system anyway.
  20. C4B12
    6 Oct 2011
    Oh! Im actually thinking about making a custom reservoir as well, for my CURV3D project, I just dont know how really haha. Looking forward to see how it works out for you. :)
