Case Mod - Complete Project: Mini Metis Maximus (ITX X99 watercooled)
Discussion in 'Project Logs' started by Combatus, 6 Oct 2016.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Any new updates Ant?
  2. Vault-Tec
    30 Aug 2015
    Looking at Custom PC mag it seems Anthony is a very busy boy, sadly.
  3. Combatus
    16 Feb 2009
    Apologies chaps - Vault-Tec got it in one! This year has been slow progress cos 'people' keep releasing these things called processors and motherboards, and guess who reviews them for a living.... I stopped working at 10:30pm last night - been lots of those recently! Urgh. Anyway, I'm working on a major update here as the project is nearly complete and ready for what must be its fourth final assembly! ha ha!
    neSSa, AleksandarK, Vault-Tec and 2 others like this.
  4. mnpctech
    21 Apr 2003
    Loving the Layout photo!
  5. Arboreal
    21 Jan 2011
    Ant, great to see the X99 Metis lives, and is still in progress. GLWB
  6. Vault-Tec
    30 Aug 2015
    It's alive sort of :D
  7. Cheapskate
    13 May 2007
    :worried: So many motherboards around him, he has to label them.
  8. Combatus
    16 Feb 2009
    You have no idea how true that is.
  9. mnpctech
    21 Apr 2003
    any Final photos yet, Ant?
  10. Combatus
    16 Feb 2009
    Soooooo, I think we might finally be gearing up for a for a final, final, yes finally final build. Unfortunately, my dad has been ill so all my spare time has been spent seeing him or on the phone related to that. My other half is also unwell and I was actually in the back of an ambulance myself a few weeks ago - thankfully I'm okay, but sadly zero free time means zero modding.
    However, I did have a few snags including yet another dead DDC pump, a leak as well as need to re-spray the front panel (god damn you spray lacquer) and fix a sagging reservoir. Due to the design, most of these things require a complete strip down and rebuild which takes around 4 hours. I also ditched the Aerocool fan as it just wasn't powerful enough so it's back to Noctua :happy:
    There's one final thing to do, which is to try out some 2K clear coat in a can, which is meant to provide a harder more scratch resistant finish. So that's my next goal once I've sorted my heated spray rig out. However, as it's hideously expensive and only lasts a day or two once mixed in-can, I'm going to take the first few steps in my next build, which also needs a touch of clear coat, which is why some of you may have seen me fiddling with a Phanteks Shift recently :) It is my next build, despite the fact this one isn't finished yet, but they had to overlap due to the cost of 2K spray cans. Watch this space :happy:
  11. Cheapskate
    13 May 2007
    Been there. Take your time.
  12. mnpctech
    21 Apr 2003
  13. Combatus
    16 Feb 2009
    Well here she is folks. I only needed a couple more hours work and some photos, but sadly my dad lost a two year battle against cancer a couple of weeks ago so I've only recently had any motivation to do anything other than feel pretty crappy.
    Big thanks to Raijintek and Overclockers UK, Mnpctech, Intel UK, Corsair, ASRock, MSI UK, Samsung UK, CableMod, Noctua, Bitspower, Alphacool, Watercoolinguk, SilverStone, Mayhems and Global Art Supplies
    Final specs:
    Case: Raijintek Metis with SilverStone remote control
    Paint: Rattlecan Montana gold supermarine blue + marble effect + 2K clear
    Feet and grille: Mnpctech mini case feet + 140mm rotating insert
    CPU: Intel Core i7-6950X (watercooled)
    RAM: 32GB Corsair Dominator Platinum Special Edition
    Motherboard: ASRock X99E-ITX/ac (watercooled)
    GPU: MSI GTX 1070 Aero (watercooled)
    SSD: Samsung 1TB 960 Pro (watercooled)
    PSU: Corsair SF600
    Cables: Custom CableMod
    FAN: Noctua AF-14 Industrial
    CPU waterblock: Bitspower ASRIX99 Monoblock
    GPU waterblock: Watercool Heatkiller IV
    Radiator: Black Ice SR2 Xtreme 140mm multiport
    Tubing and fittings: Alphacool chrome brass tubing and fittings
    Pump: Laing DDC
    Reservoir: Phobya Balancer 150
    You'll notice that the power button has gone - I actually filled it in and resprayed the front panel a while back. I also used 2K clear coat this time as the slightest ding would scratch the standard stuff. It looks fabulous and my photo skills really don't do it justice!
    This must be like the 20th water-cooled mini-ITX PC I've built and despite having my main rigs watercooled for 15 years, I still learned a huge amount with Metis. I'm pretty happy with it, but there are plenty of areas I'm not so happy too. In order to cool a Core i7-6950X and GTX 1070, I had to use a full size 140mm rad, but a single 140mm fan in an enclosed space means the RPM is just too high/loud for me. It copes, as I knew it would, so concept was proved, but as an every day rig being paired with my sensitive ears...well, it's just not quiet enough.
    It will be my daily driver for a while, but I'm already working on a Phanteks Shift build that will be even more powerful and of course water-cooled, but with several 30mm rads.
    _MG_1930.jpg _MG_1932.jpg _MG_1933.jpg _MG_1934.jpg _MG_1935.jpg _MG_1936.jpg _MG_1937.jpg _MG_1940.jpg _MG_1942.jpg _MG_1946.jpg
    TheMadDutchDude likes this.
  14. Combatus
    16 Feb 2009
    _MG_1947.jpg _MG_1948.jpg _MG_1949.jpg _MG_1950.jpg _MG_1951.jpg _MG_1952.jpg _MG_1953.jpg _MG_1956.jpg _MG_1957.jpg _MG_1959.jpg
  15. Combatus
    16 Feb 2009
    mnpctech, _Prometheus_ and Dot_Kappa like this.
  16. David
    7 Apr 2009
    That looks sweet. Great build, Ant.
    mnpctech likes this.
  17. mnpctech
    21 Apr 2003
  18. Combatus
    16 Feb 2009
    Thank Bill! I have to say that those Micro PC Case Feet of yours are absolutely made for this build!
  19. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    Absolutely cracking. I will say I'm not mad keen on the fitting-fest from the SSD into the rad, but it's so tight in there I'm not sure you could've done anything else.
    Top job.
  20. Sn00k3r
    Sn00k3r What's a Dremel?
    7 Apr 2011
    Great Design, love those compact builds :clap:
    Sick Paintjob btw, love it..! :grin::grin::grin:
