Scratch Build – In Progress [Project Mod] "SOUL TREE AVATAR"
Discussion in 'Project Logs' started by DEFCON Emy, 19 Nov 2010.
  1. DEFCON Emy
    DEFCON Emy The Emy Charger
    16 Nov 2007
    Explained better, I did not understand what are the TIR ... ....
    How do I get the light effect on the entire fiber?
  2. k4p84
    k4p84 What's a Dremel?
    20 Aug 2008
    Hey,
    TIR is total internal reflection, the process by which the light light can travel down the fibre via reflecting off the internal surfaces.
    You will need to remove all the cladding and coating to get the side glow effect.
    I would recommend you use plastic optical fibre (POF) as it firstly much bigger in general and is far more forgiving.
    Alternatively you can google 'plastic optical fibre side glow' and find a local source.
    Regards
    Ed
    kelmannen and Waynio like this.
  3. Ulti
    Ulti Poor student
    20 Jun 2012
    Wow, this is very artistic! Love your attention to detail!
  4. Waynio
    Waynio Relaxing
    20 Aug 2009
  5. Andy Mc
    Andy Mc Modder
    23 May 2002
  6. k4p84
    20 Aug 2008
    No problem
  7. DEFCON Emy
    16 Nov 2007
    Thank you so much for the info k4p84.....:clap:
  8. DEFCON Emy
    16 Nov 2007
    Proceed slowly due to a problem with fiber optics, sanding it not give me a satisfactory effect lighting level, anyway I wired the first led Strip on the first branch ...
    And then today I went to withdraw the plexiglass for my liquid cooling tubs .....
    Bye bye.......
  9. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    oooh... shiny! :)
  10. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    Yup, a sideglow POF will give you what you want...much better than sanding would.
  11. DEFCON Emy
    16 Nov 2007
    Waiting for the bundle of optical fibers with side lighting from China ... ... I dedicated to pools for liquid cooling. Here are the cuts:
    Now we're going to glue the first pieces to the Bowl containing my action figure Jack Sully ... ...
    I later realized tubes of inlet and outlet of the bath great ..... ...
    Now we practice holes on the Central cylinder ... ... ... and the subsequent application of little tubes ... ...
    Here's the finished work in respect of the first Assembly of the pieces of the tanks ..... ...
    Stay tuned........
  12. bluc
    bluc What's a Dremel?
    4 Apr 2012
    Are you going to use led strips for the branches or optic fibre? IMO optic fibre fed from a rgb light source would be better.:confused:
  13. DEFCON Emy
    16 Nov 2007
    Until I get the optical fibers with lateral lighting, I finished the large tub, one that will go under the tree. After doing the hole I threaded with a tap from 1/8 to seat the hose (commonly used for wash basin mixers), which will have the task to let
    the liquid inside the tank ... ... ...
    Water tightness test and subsequent discharge when the wired valve at the bottom of the flexible tube...
    One of the two plugs that will block the hole filling and bleeding ..... ...
    Final closing of the bowl .... ....
    Ciauzzzzz.
  14. ASPHIAX
    ASPHIAX Minimodder
    1 Feb 2011
    Nice ! Awesome creativity ! Subbed for sure !
    PM me if you went for side glow and want to get rid of the ikea strands you've got !
    I could use them for my new build !
  15. DEFCON Emy
    16 Nov 2007
    Surely I will use one part, but will remain as much fiber as that of Ikea, when you will contact me .... ...
    I'll give what you need.
  16. DEFCON Emy
    16 Nov 2007
    New up. .. .... today I am dedicated to the support of the pan containing Jake Sully, I used the wood since it has good machinability, then I already had at home and the thickness was perfect ... ... .... Seeing a screen shot of the movie I started to draw the shape ... ...
    After being cut with the jig saw I took measurements of the three holes of the Pan and precisely at the Center and on the sides, that of entry and exit ... ..... and I scored the wood to make the next cut ... ....
    Now at the openings on wood a centered point wood and after to pierce the plexiglass ... ... ...
    At this point, as in the first tank with small tubes of plexi, I go to paste them into their housings to inlet and outlet .... ...
    Then after the two fill holes and vent, I closed the tray with my Jake waiting for watertight test. .....
    Stay tuned...........
  17. Waynio
    Waynio Relaxing
    20 Aug 2009
    Looking forward to what comes next & have been & will be doing all the way, what you are doing looks extremely ambitious. :hip::)
  18. bluc
    4 Apr 2012
    Love the avatar hybernation growth chamber thingy :D :rock:
  19. DEFCON Emy
    16 Nov 2007
    Pan test OK .... ....
    And fiber optics to side lighting arrived ... ...
    And now at work!!!!!!!!!
  20. GamerIDGoesHere
    GamerIDGoesHere www.^.com
    3 May 2012
    Wow. Just wow. This Blew me away. If you can pull this off, it will be amazing. Nice idea with the Avatar hibernation thing, is that going to be the reservoir?
    Keep Up the awesome modding, and subbed.
    - Dan
