Project: Puzzlebox Pc (10/09) COMPLETED!!
Discussion in 'Project Logs' started by [WP@]WOLVERINE, 14 Aug 2004.
  1. [WP@]WOLVERINE
    [WP@]WOLVERINE What's a Dremel?
    18 Oct 2003
    So now its time for a brand new casebuild :) This time with a Hellraiser theme. This case will be my servercase
    and will contain an old P4 1,7 The case vill be an engraved plexicube. The idea is to make an all black and gold
    cube, to do this i will dremel all the patters and then fill them with leafgold and top it off with sunblock film
    on the inside.
    The cube will remain black and gold until the lights switch on. Then the internals will be visible. The mainboard
    will be mounted with all connecters facing down this will be done so that i can hide all the cables in the wodden
    base. The cdrom and diskdrive will also be stealthed into the base so that the plexicube itself will remain
    untouched.
    I didnt want to cut any holes in the cube since i feel that it would mess up the clean look im going for the only
    holes will be for 2x80mm casefans one in the front and one at the back. Ive made some sketchup drawings to show
    yall what i had in mind
    So now on to the actual build, first some plexi
    Then some sketching, this will take forever to do with the old dremel but ill get there :)
    Ill be back with more soon :)
  2. LF Hazard
    LF Hazard What's a Dremel?
    29 Jul 2004
    did you draw those markings on the plexi??? damn man, if you did, then you are the most persisting one ive ever known
  3. JavaDog
    JavaDog What's a Dremel?
    13 Mar 2004
    Make sure you are careful, Polycarbonate is strong, but scratches VERY easily... :thumb:
    By the way, those are some killer drawing skills...can't wait to see this etched!! :D
  4. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
  5. exavier412
    exavier412 What's a Dremel?
    15 Jan 2004
    wow.... that looks like it'll be good.. although i have seen a hellraiser puzzlebox mod before.. it was actually the mod taht got me into this 'scene'.... let me find a link......
    http://www.sheff.com/projects/HellRaiser/hellraiser01.html
    wow this is old... now that i think about it (i totally forgot about it) i wanna make a small cube case... lol...
  6. mrplow
    mrplow obey the fist!!
    5 Sep 2001
  7. toand
    toand What's a Dremel?
    17 Feb 2004
    At it again are we? :D looking good! Loved the Blacklight demons case, I'll be subscribing to this one for sure! :D
  8. Firehed
    15 Feb 2004
    Wow, that's one of the most interesting concept I've ever seen! Not sure how you plan to connect cables to the i/o ports on the mobo as they're facing the bottom but I'm sure you already thought about that. Good luck with the dremel :)
  9. KG Silent
    KG Silent What's a Dremel?
    4 Aug 2004
    just... ****ing... amazing... :clap:
  10. Rain
    Rain What's a Dremel?
    16 Jun 2002
    Cant wait to see the end result :jawdrop:
  11. nicke
    nicke What's a Dremel?
    17 Jun 2004
    looks like another great, top rated, excellent, sup3rb case by you WOLVERINE
    hälsningar från finland :D
  12. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    this is going to turn out great just as your last project! looking forward to see the engravings. you're the engraving guru, so this just have to turn out amazing! good luck pal!
    have fun, go mad :D
  13. Atarax
    Atarax What's a Dremel?
    13 Jul 2004
    good job keep it up
  14. TomboyMS
    TomboyMS What's a Dremel?
    6 May 2004
    Wow!
    Damn! This case is going to be a real work of art. :thumb: :thumb:
  15. Litecore
    Litecore What's a Dremel?
    21 Sep 2003
    saw pictures of this one just a few days ago but i must say that
    it's still one of the most impressing cases i have ever seen!
    you, my good sir, have awsome dremel madskills and i know
    this case will be a hell of a kickass-m0d when it's done :thumb:
    WOLVERINE is our very own Swedish superstar :clap:
    i sure will follow this project, you mod on !
    :dremel:
  16. R@Mo
    R@Mo What's a Dremel?
    14 May 2004
    Are you still working on translating into English the etching FAQ from your last thread? :D
  17. Acid Burn
    14 Mar 2004
    If you want me to, I can do it...
  18. [WP@]WOLVERINE
    18 Oct 2003
    -=Update=-
    So now im back again :) Ive been working hard theese last couple of days and what ive been up to you can see here
    Ive finished 2 sides of the cube, not completely but ive got all the basic etching done and heres how it looks.
    And the work continues....
  19. hmekk
    hmekk What's a Dremel?
    17 Jul 2004
  20. Acid Burn
    14 Mar 2004
    Amazing work as always mate! you said one of the colors is going to be gold, have you god gold leds or are you going to paint the parts gold?
    EDIT:
    never mind, I'm retarded :p
