Case Mod - In Progress Purple Rain / CustomPC 'Readers Drives' - Issue 81 / Apr '10
Discussion in 'Project Logs' started by mrdbristol, 3 Jul 2009.
  1. mrdbristol
    mrdbristol Voided my warranty years ago
    8 Aug 2008
    Made a start on the re-tubing.
    Out went the white tubing and in came the braided tubing ;
    Looks far better imo.
    A bit different from standard tubing :D
    More to come.........
  2. Interloper
    Interloper Faux Pro Modder
    17 Jul 2009
    Oh hell yes that looks WAY better! Not that the white was bad, but this is plain sexy!
  3. stuartwood89
    20 Aug 2008
    Agreed, the purple bits really make it look good.
  4. The boy 4rm oz
    10 Apr 2008
    IMHO it looks good, but not as good as the white. The white is such a sharp contrast, makes you go "WOW, look at that", the sleeve just doesn't have the same effect on me.
  5. Quavr
    Quavr Minimodder
    3 Jul 2009
    that looks really good, really like how the tubing looks ith the braiding
    nice job, can't wait to see this when it's finished :D
  6. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    Thats really....Purple :worried:
  7. mrdbristol
    8 Aug 2008
    Cheers for the replies.
    The tubing will be a Marmite thing, i guess.
    The white tubing was fine, but i wanted something different - So only when its finished will i see whether it was a good or bad move :)
    Anyway, bit of an update.
    A few more bits done.
    To cutdown on cabling, i made a small SATA power cable for the 2 HDDs and the DVD drive.
    Cut the wires to length;
    Strip the sleeving at the required points;
    Heatshrink the wiring that will show;
    Add the braiding;
    Then just slot the bare wires in the correct slots on the connector.
  8. mrdbristol
    8 Aug 2008
    More tubing has been braided, here's some random shots;
    My camera doesn't like purple and turns it into blue for some reason :(
    Cheers for looking :thumb:
  9. Hansge
    Hansge What's a Dremel?
    30 Sep 2009
    Woa, thats sexy! Great mod there! Love the tubing.
  10. Skorchio
    Skorchio What's a Dremel?
    16 Oct 2009
    Great build mate, very clean and i love them cases :). Where can i get my hands on braiding like that be great if they do some white with blue, suite my build down to the ground.
  11. Guest-23315
    Guest-23315 Guest
    Very nice :thumb:
  12. stonedsurd
    11 Mar 2009
    Every time I see those Tacens fans I go "ooh!".
  13. bagman
    bagman Minimodder
    18 Apr 2009
    i really like this project and i have to agree that the tubing braded looks awesome and much better
  14. mrdbristol
    8 Aug 2008
    ChilledPC.co.uk do a very good range of their own braiding now.
    They do a Blue and white braid which might suit your build.
    http://www.chilledpc.co.uk/shop/popup_image.php?pID=1411
    Mention my name :D
    The braid i'm using came direct from America via my very generous sponsor Techflex ( See front page for links )
    Cheers.
  15. Arnakke
    Arnakke What's a Dremel?
    6 Jun 2007
    'Trial and error'...?
    I would like to throw a few 'cents' your way.........
    This is what I see colour- wise:
    1. purple 'boxy/container'
    2. purple/white electric wiring
    3. org. white ... now changed P/W 'cooling' tubing.........
    I think I understand what 'stonedsurd' means by 'too loopy'...white makes things look larger and with long loops it takes up that much more (eye-catching) 'space' .
    But I also see 'mrdbristol's point....tubing that connects/shows the cooling circuit, which is very central.
    I would like to suggest to you, 'mrdbristol', that you might consider going back to the white tubing, but use right angel 'tubing elbows'? The right angels of the tubing and the right angels of the the 'boxy' container. And I think (?) the colours will be in a nice relationship/balance to each other.
    Hard to improve on perfection, ain't it just!
    Thanks for letting me comment!
  16. skunkmunkey
    skunkmunkey Minimodder
    15 Jul 2007
    Loving the purple, have a bit bit of a penchant for all things purple myself. I like how the sleeving matches the purple too.
  17. Cheapskate
    13 May 2007
    I'm a fan of purple too. The only thing you are missing is some purple plexi. :naughty:
    I like the sleeved hoses. It's very clean. The only spot on the whole system I don't like is the snarl coming out of the PSU. It screams 'cover me!'
  18. waffle911
    waffle911 Grappling with Torque Steer Daily
    16 Mar 2009
    That looks pretty purple to me :thumb:. More of an indigo, really, but it's not really truly blue. I think your monitor's just a bit off (mine's calibrated pretty well from the factory).
  19. Gateway
    Gateway ...
    28 Nov 2007
    In the second i saw this project name, this came to my mind ^^
    Great project!
  20. mrdbristol
    8 Aug 2008
    Another small update before i disappear for a couple of weeks holiday :)
    Am going to use the 2 120mm roof fans for some internal lighting.
    3mm white LEDs with metal bezels;
    Enlarge the fan screw hole by a couple of mm , then simply fasten the nut to the back of the bezel;
    Even though it will be on the roof, and out of sight, more braiding.....
