A quick mention of thanks to Darth Beavis who kindly sent me a fan ring to replace the missing Red one. Cheers Mate!
Leaktest underway,i want get the board fired up this week and get to work stressing the GPUs that are coming this week,they have to pass 24 hrs on furmark before i put blocks on them.. Only one leak from the Vid connector on the pumps,needed brutal tightening to get it watertight,other than that,leak free so far! Having seen what one 24v D5 can do,the second was pure overkill!
Progress gets a boost today...sadly i must break the loop down to wrap the sides of the rads and the pump mounts with Di-Noc,this fill-up was a fittings test. A second 670 appears!
3m,i <3 You... I wanted to cover the sides of the rads and the pump mounts with DiNoc,i quite like the look of carbon fiber and this stuff is easy to work with. Trim off the excess. To get the stamping to show,i used a heatgun and a paint brush to mold the sheet. Now to start on the pumps. They look not so good stock,but we are going to change that.. I started this by giving the mounts a once over with some black etch. Then hit it with the DiNoc. Much Better!!
My god.... Holy mother... (I can go on with this rant) Your build is making me nuts atm, Ultra clean, and Im loving your cable sleeving choice, and your choice in GPU, Rocking that 670 gtx Cheesecake
Thanks mate! Another 670 to get yet... plus Watercool HK blocks... and a Lamptron FC 10..... But in the meantime... Braid.....all i see is braid....XD But i also have the shiny!!
the carbon overlay on the rads and pumps looks SICK!!! still lovin this build!! have you considered carbon on the drive bays?
I'm doing some painting on the exterior,no DiNoc.... DiNoc is best used sparingly,it looks odd when its over done. That's my opinion anyhoo.. Thanks for all your comments,nice to see people interested! Got a scratch build pod build in the works for next year. Should be fun!
