Scratch Build – In Progress The Wood Brothers
Discussion in 'Project Logs' started by Razarach, 24 Dec 2012.
  1. metalglasses
    metalglasses What's a Dremel?
    10 Apr 2012
    Looks good so far, I would like to see what kind of siding you will produce.
    Just a tip about the wood, I don't know if you know this, if you do, kind of disregard the tip. When you glue wood side to side, make sure that the bindings are opposed. I noticed on the bottom that the bindings are not opposed, chances are it could be fine, but it could warp a little depending on where you'll be storing the case. I actually broke that rule on my project (deliberately) on the floor board on my desk.
  2. siliconfanatic
    siliconfanatic Johny-come-Lately
    10 Sep 2012
    bindings? my wood vocab is rather dimunitive:sigh:.
  3. Razarach
    Razarach Minimodder
    28 Jan 2009
    Another update is here. :D
    Thanks. Side panels will be done tomorrow, but I'm not sure should I use removable panel or just glue it and use it like motherboard tray.
    Thanks for the tip. :)
    HDD case in da haus! :D
    I decide to go with space for five drives, and some space for Raspberry Pi.
    Also i made radiator standoffs for easy radiator removal.
  4. biojellywobbles
    biojellywobbles Minimodder
    12 Feb 2011
    Wow, this is going to be damn impressive :D
  5. Cheapskate
    13 May 2007
    Oh, cool. So the pegs will be on the radiator and it will just slide in... cup, things.
  6. Razarach
    Razarach Minimodder
    28 Jan 2009
    I hope so, thanks.
    Exactly :dremel:
  7. siliconfanatic
    10 Sep 2012
    nice save. i soooo would've taken that out of context given the chance.:lol:
  8. OcSurfe
    OcSurfe Uber Noob
    7 Aug 2012
    looks good,
    keep it up
  9. Razarach
    Razarach Minimodder
    28 Jan 2009
    Thanks
  10. Razarach
    Razarach Minimodder
    28 Jan 2009
    Hi guys,new update is here. :dremel:
    I cut the hole for I/O ports.
    Also i monted the radiator.
    [​IMG] [​IMG]
    And i got remaining parts for water cooling.
    To cool down water pump i got some old CPU heatsink.
    [​IMG] [​IMG]
    And finally sneak peak for tomorrow job.
    [​IMG] [​IMG] [​IMG]
  11. biojellywobbles
    12 Feb 2011
    Are we going to see a custom res per chance :naughty:
  12. Razarach
    Razarach Minimodder
    28 Jan 2009
    Yes :dremel:
    Today I finished reservoir.
    After drilling, gluing and stuff I got nice clean res.
    [​IMG][​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  13. dombak1608
    dombak1608 What's a Dremel?
    3 Apr 2012
    Great work!
    I like the res. :clap:
  14. Razarach
    Razarach Minimodder
    28 Jan 2009
    Thanks!
  15. Razarach
    Razarach Minimodder
    28 Jan 2009
    Little update today. :)
    After some thinking I figure out how to mount the pump.
    On down side pump has two unused 4mm holes.
    I cut two 2 cm aluminum pieces and drill holes in it.
    And this is how it looks when mounted.
    One notice, screw is going through down side of the case and holding all that together.
  16. Razarach
    Razarach Minimodder
    28 Jan 2009
    Last important construction piece is done.
    I present to you mobo tray.
    Measure twice, cut once. :D
    Mounted.
    Lets see how mobo fits.
    Few extra pic. :dremel:
    I still need to mount two thermometers and first phase is over.
  17. siliconfanatic
    10 Sep 2012
    Thats one massive chipset cooler. and one sexy piece of acrylic reservoir :D
  18. Razarach
    Razarach Minimodder
    28 Jan 2009
    @siliconfanatic; thanks
    Long time no see. Time for another update.
    Apogee block didn't come with AMD mounting plate so I need to made one. I decide to use plexiglass.
    After some testing I found some screws and mount block on motherboard.
  19. dreps
    dreps Minimodder
    3 Oct 2012
    looking good so far
  20. Razarach
    Razarach Minimodder
    28 Jan 2009
    Thanks!
